Salta al contenuto principale
Xelio P900A-BK Front Facing Camera Replacement
Cosa ti serve
  1. Xelio P900A-BK Front Facing Camera Replacement, Front Facing Camera: passo 1, immagine 1 di 1
    • Remove the two 5.4mm bottom screws.
    • Set aside.
  2. Xelio P900A-BK Front Facing Camera Replacement: passo 2, immagine 1 di 3 Xelio P900A-BK Front Facing Camera Replacement: passo 2, immagine 2 di 3 Xelio P900A-BK Front Facing Camera Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool between the screen and the rear case and carefully pry the tablet open.
    • Gently work your way around the entire tablet and do not force the case open prematurely.
    • You will hear the plastic latches pop free.
  3. Xelio P900A-BK Front Facing Camera Replacement: passo 3, immagine 1 di 1
    • Remove the connection between the camera and the motherboard.
    • Open the black ribbon holder then remove the ribbon from its connection.
  4. Xelio P900A-BK Front Facing Camera Replacement: passo 4, immagine 1 di 1
    • Remove the tape covering the front facing camera entirely to expose one of the motherboard screws.
  5. Xelio P900A-BK Front Facing Camera Replacement: passo 5, immagine 1 di 3 Xelio P900A-BK Front Facing Camera Replacement: passo 5, immagine 2 di 3 Xelio P900A-BK Front Facing Camera Replacement: passo 5, immagine 3 di 3
    • Use the smaller plastic opening tool to remove the camera from its socket.
Conclusione
Marcus Nelson
Membro da: 03/26/15
307 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 112
