Salta al contenuto principale
How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering
Cosa ti serve
  1. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering, Xbox Series (Model 1914) Trimmer Potentiometer Sensor: passo 1, immagine 1 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering, Xbox Series (Model 1914) Trimmer Potentiometer Sensor: passo 1, immagine 2 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering, Xbox Series (Model 1914) Trimmer Potentiometer Sensor: passo 1, immagine 3 di 3
    • Before you begin, remove the two double-A (AA) batteries from the back of the controller.
    • Wedge your spudger into the seam between the back and side panels.
    • Grip the controller firmly and pry the side panel away by moving the spudger back and forth. Work your way around the entire seam using this motion.
  2. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 2, immagine 1 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 2, immagine 2 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 2, immagine 3 di 3
    • One of the five 2.4 mm screws is located in the middle of the battery container.
    • You can either peel the sticker or punch a hole through the center to access the 2.4 mm screw.
    • Remove the screw in the middle using the TR8 Torx screwdriver. Also, remove the two 2.4 mm screws on both sides of the controller.
  3. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 3, immagine 1 di 1
    • Remove the back panel.
  4. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 4, immagine 1 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 4, immagine 2 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 4, immagine 3 di 3
    • Turn the controller over and remove the front panel.
    • Remove both thumb sticks by pulling them up.
  5. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 5, immagine 1 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 5, immagine 2 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 5, immagine 3 di 3
    • Turn the controller over and remove the two 1.75 mm screws using the T6 Torx screwdriver.
  6. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 6, immagine 1 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 6, immagine 2 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 6, immagine 3 di 3
    • Do not use excessive force when you pry open the sensor housing since it can damage it.
    • Face the controller up, and with your tweezer, open the sensor housing by gently pushing away from the analog stick sensor.
    • Pull the old sensor wheel out of the sensor housing.
  7. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 7, immagine 1 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 7, immagine 2 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 7, immagine 3 di 3
    • Align the sensor wheel so that the sensor arms are facing upwards.
    • Insert the sensor wheel into the sensor housing.
    • Push the sensor housing back in using the spudger to close it back in.
  8. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 8, immagine 1 di 1
    • You will repeat steps 6 and 7 for the other three sensor wheels.
  9. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 9, immagine 1 di 2 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 9, immagine 2 di 2
    • Push the analog sticks back into the analog stick sensors.
  10. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 10, immagine 1 di 2 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 10, immagine 2 di 2
    • Screw back in the 1.75 mm screws using the T6 Torx screwdriver.
  11. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 11, immagine 1 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 11, immagine 2 di 3 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 11, immagine 3 di 3
    • Flip the controller over and place the front panel back.
    • Turn it around and align the back panel so that the two battery terminal contacts are outside.
  12. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 12, immagine 1 di 1
    • Screw back the 2.4 mm screws using the TR8 Torx screwdriver.
  13. How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 13, immagine 1 di 2 How to Fix Xbox Series (Model 1914) Controller Stick Drift Without Soldering: passo 13, immagine 2 di 2
    • Push the side panels back in place.
Conclusione
I hope this guide has been helpful!
Altre 2 persone hanno completato questa guida.
1Commento della guida
Es no funciona ya que directamente los contactos de carbono de los potecimetros son los que están ya desgastados debido a la friccion de funcionamiento, directamente se debe de reemplazar los potecimetros completos, no únicamente el sensor de contacto.
JCBrokeS995 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 22
Ultimi 7 Giorni: 178
Ultimi 30 Giorni: 678
Tutti i Tempi: 3,047
