Introduzione
This guide details how to take off the outer plastic case of the Xbox One X. This could be useful for replacing the case itself if it is damaged. Removing the outer case is also necessary for replacing any of the interior components. Before starting, it is recommended that you make sure you have the right tools as well as a clean environment with plenty of room for organizing the components. Be aware that disassembling your Xbox could void your warranty, so you may want to read those terms and conditions in advance.
Cosa ti serve
Use a T9 Torx screwdriver to remove the 13mm screw which is under and to the left of the power input.
Altre 7 persone hanno completato questa guida.
2 Commenti
Where do you get the outer case from? And if I only want to replace the outer case could I just follow the first 3 steps?
Following. I need a replacement project Scorpio case. the system I got it from was from Mercari and the guy did a poor job in taking care of the case and I need a top Scorpio case.
