Salta al contenuto principale
Xbox One Wireless Controller Trigger Rumble Motor Replacement
Cosa ti serve
  1. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Battery Pack: passo 1, immagine 1 di 1
    • Remove the battery pack cover.
    • Remove batteries.
  2. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Side Handles: passo 2, immagine 1 di 2 Xbox One Wireless Controller Trigger Rumble Motor Replacement, Side Handles: passo 2, immagine 2 di 2
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Start prying the side plate off underneath the trigger, this makes it easier to disconnect the other clips connecting the side plate to the backplate.
    Brandon - Replica
    One you take it off, is it possible to click it back in?
    Aiden Bear - Replica
    As long as you don’t exceed the couple tons you need to take it off you should be able to put it back.
    Brandon -
    I don’t have a squdger
    TimidFerret4982 Gaming - Replica
    getting those handles back on seems impossible, they just dont fit as well, a gap remains even after snapping into place.
    Dont think ill be doing this in the future
    Spoutin Wyze - Replica
    edit: wiggled the bo9ttom middlewith the handles off and somethign finally “clicked” into place for that extra 1/4 mm for the down arrow on my D-Pad to click back up into place!.
  3. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Screws: passo 3, immagine 1 di 2 Xbox One Wireless Controller Trigger Rumble Motor Replacement, Screws: passo 3, immagine 2 di 2
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    i damaged my screws. how do i get the screws out?
    tenzin - Replica
    wait. i just watched a video guide on ifixit's youtube channel about damaged screws. i'll try those methods.
    tenzin - Replica
    It's a t8 or t9 security bit btw, I got the top two out with a regular T8, but the bottom two and middle needed a T9 Security bit.
    David Loper - Replica
    All five faceplate/backplate screws in the controller I disassembled were T8 security fasteners.
    John Dziedzic - Replica
    Am I doing something wrong because I got the tool it said I needed and got the middle screw out but the others have a bump or something in the center of the screw and it won't fit.
    kolton77 - Replica
    The T8 is only good for the middle screw on my One S controller. The others require something bigger
    Matej Skelo - Replica
    These requires SECURITY Torx bits (they have a cannulated hole in the driver). I don't believe the iFixIt branded driver is cannulated but you can buy a set of bits from DeWalt DWAX200 which is overkill but has what you need.
    jhighsmith - Replica
    The driver that iFixIt sells is cannulated.
    jhighsmith -
    where do you get this dumb ass screw driver
    Jake Zweier - Replica
    iFixit Store #IF145-027-3
    VauWeh - Replica
    You can bypass it with a 1.5mm flathead.
    Marianne Sandling - Replica
    thank you for this. worked for me
    Mr Anderson (Evolluisionist) -
    These screws required a T10, not T8.
    Armand - Replica
    TR9. A $10 kit from Walmart has the bit/driver in it and extra goodies to make life simple.
    Matt Martin - Replica
    As weird as it sounds, the top 2 came out for me with a flathead- but the bottom two and the middle one wont
    macybrooksevans - Replica
    If you damage the middle part of the screws you can still take it out with the same screwdriver.
    Kev God - Replica
    Thank-You :)
    Isaiah - Replica
    needed a T8H, not easy to see.
    on a grey green xbox one controller
    Michael - Replica
    On my 1708 controller there are two internal screws near the rumble motors that need to be removed with a T6 non security bit to remove the back cover.
    teeedubb - Replica
  4. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Backplate: passo 4, immagine 1 di 1
    • Remove the backplate.
  5. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Faceplate: passo 5, immagine 1 di 1
    • Remove the faceplate.
  6. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Top Motherboard: passo 6, immagine 1 di 2 Xbox One Wireless Controller Trigger Rumble Motor Replacement, Top Motherboard: passo 6, immagine 2 di 2
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
    Steps 6-8 aren't completely necessary, and are very risky if you aren't good at soldering. It would seem the only reason to remove the motherboard and mess with all this soldering is just so you can reach both screws on the trigger in step 10. However, you can reach them already with a small-bodied screwdriver. Although you might have to rest the screwdriver on the black square processor to reach the bottom screw, it shouldn't damage the processor or motherboard to jimmy that screw out.
    Robert Rapier - Replica
    like mentioned by ‘Robert Rapier’ you can skip the de-soldering in most cases,
    for example cleaning or changing the buttons is doable, but the grey and black wires are pretty short
    and wired through the inner case so it can get a bit fiddly and you have to be careful not to damage them in the process.
    If you have a soldering station around i would still recommend using it.
    yKekS Yzz - Replica
    Thanks to above commenters. Can confirm I was able to do a button repair without soldering. Thank you all!
    Matt Hunt - Replica
    If you peal back the Kapton tape mounting the grey/black wires there is enough play to maneuver all the boards for cleaning most of the buttons from a soda spill. Cleaning the dimple buttons on the mother board by immersion requires the de-solder...
    agzero - Replica
  7. Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 7, immagine 1 di 1
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    Are these just T6 screws or Torx security T6 that is cannulated?
    Kenan Vickstrom - Replica
    The outer screws are security screws. The ones on the system boards are Torx.
    Rongwey -
  8. Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 8, immagine 1 di 1
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
    Hola, como se instala el software a la nueva placa base ?
    MANSONN755 - Replica
  9. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Trigger Rumble Motors: passo 9, immagine 1 di 1
    • Remove the yellow tape holding the wires in place on the front of the controller.
  10. Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 10, immagine 1 di 3 Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 10, immagine 2 di 3 Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 10, immagine 3 di 3
    • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
  11. Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 11, immagine 1 di 1
    • Remove the trigger covers.
  12. Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 12, immagine 1 di 1
    • Desolder the wires from the motherboard.
    • Remove the rumble motors from its socket and pull the wire with it.
    Perso après le remontage ça n'a jamais refonctionné ma manette détecte plus du tout les gachettes et jai changé les joysticks en même temps et eux non plus ne detecte plus….
    Tuto Free - Replica
Conclusione
Altre 19 persone hanno completato questa guida.
Tommy
Membro da: 01/22/15
1.909 Reputazione
2 Guide realizzate
Cal Poly, Team 20-15, Maness Winter 2015 Membro di Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membri
50 Guide realizzate
10 Commenti
After a drop onto tile flooring, the side clip of the outer handle snapped and got lodged into the trigger, causing it to only pull to 80% and go no further. Thanks for this breakdown.
solofrom303 - Replica
My right trigger won't work on gta 5 and on other games it works
Devean Velasquez - Replica
Very strange, Devean. That sounds more like a software problem than a hardware problem, if I had to guess. If you haven't already, maybe check to make sure that your control setup is correct.
Alternatively, see if you can find any other games that your RT doesn't work for, and see what they have in common with GTA - it might be that the trigger isn't registering as fully depressed, or only ever registering when fully depressed.
Liam Gow -
Trying to replace bumpers assembly and green sync button fell out can not figure how to put it back in.
Anthony Bembenek - Replica
Do you know how to remove the plastic plate where the trigger rumble sits?
Angel Marban - Replica
Could you not just pull the wires?
Spencer Alty - Replica
How do you place the wires back onto the trigger rumble?
Timmy Sparkles - Replica
Where would one buy the replacement trigger motors?
Jared Thicc - Replica
Both wires fell out of one of the motors. How would I be able to fix this?
Abler e - Replica
can this guide be reworked to add rumble feature to the powera fusion controller for nintendo switch?
Xavier Beck - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 207
Tutti i Tempi: 59,977
