Salta al contenuto principale
Xbox One Wireless Controller Model 1708 Trigger Caps Replacement
Cosa ti serve
  1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: passo 1, immagine 1 di 2 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: passo 1, immagine 2 di 2
    • Slide the battery cover out and remove it.
    • Remove the battery pack.
  2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 2, immagine 1 di 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 2, immagine 2 di 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool between the handle and the plate.
    • Gently slide the opening tool from the top end to the bottom end of the seam to remove the plate from the handle.
    • Repeat the process with the other side plate.
    • The plate is tightly sealed on the handle, so it may be difficult to remove.
  3. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 3, immagine 1 di 2 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 3, immagine 2 di 2
    • Remove the five 2.3mm screws on the bottom plate with a T8 Torx security Screwdriver.
    • If there is a sticker on the back, poke a hole with the screwdriver to get to the fifth screw.
  4. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 4, immagine 1 di 2 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 4, immagine 2 di 2
    • Remove the bottom plate.
  5. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 5, immagine 1 di 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 5, immagine 2 di 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 5, immagine 3 di 3
    • Carefully turn over the controller with the front plate facing you.
    • Remove the front plate.
  6. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 6, immagine 1 di 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 6, immagine 2 di 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 6, immagine 3 di 3
    • Remove the two 1.7mm screws from each of the triggers with a T6 Torx screwdriver.
    • It is best to do one trigger cap replacement at a time.
  7. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 7, immagine 1 di 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 7, immagine 2 di 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 7, immagine 3 di 3
    • Be careful not to let the trigger motor inside come out.
    • Lift the trigger cap off the trigger motor.
  8. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 8, immagine 1 di 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 8, immagine 2 di 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 8, immagine 3 di 3
    • Place the new trigger cap on the trigger motor.
    • Push down the inside of the trigger cap until you hear a click.
    • Repeat step six to eight for the other trigger cap.
Conclusione
To reassemble your device, follow steps 1-5 in reverse order.
Altre 19 persone hanno completato questa guida.
UC Davis, Team S1-G6, Andersen Winter 2020 Membro di UC Davis, Team S1-G6, Andersen Winter 2020
UCD-ANDERSEN-W20S1G6
3 Membri
4 Guide realizzate
1Commento della guida
Et le reboitage stp non parce que je pense que ses le plus compliqué.
Yoann.cadenat - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 87
Ultimi 30 Giorni: 391
Tutti i Tempi: 24,334
