Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
The Joysticks on your Xbox Controller could become unresponsive or sticky. If this happens it could be necessary to remove the Joysticks to either replace or clean them. This guide will teach you how to access and replace the Joysticks on your Xbox One Wireless Controller Model 1708.
  1. Slide the battery cover toward the top of the controller to remove it. Lift up  the batteries or the battery pack from the battery compartment.
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Insert a plastic opening tool into the top seam, and  gently work the opening tool to the bottom of the controller. Continue using the opening tool to gently pry the side plate off of the controller.
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    Only use a pry tool! The vibration motor wires are exposed and directly accessible from the side when opening. I attempted to open it with a small knife, expecting to be able to gently pry the clips open, accidentally sliced through my right motor’s wires.
    Sawyer Coe - Replica
    Not a sharp of course.
    Kajus Slekys -
  3. STUDY UNPLUGGED
    Battery Fix Kits for Mac
    Shop Fix Kits
    STUDY UNPLUGGED
    Shop Fix Kits
  4. Gently peel the battery label  or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    Torx-8 security bits work as well.
    jahiamir - Replica
    Torx 8 or 9 wasn’t working. I used 2.0 minus screwdriver
    richjlee - Replica
    The 2.0 minus worked for me as well.
    metric - Replica
  5. Orient the controller so the front plate is facing up. Lift the front cover off of the controller.
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Turn the controller face down and gently lift the rear plate.
    • Turn the controller face down and gently lift the rear plate.
    Reassembly: When placing the back cover on: notice that the battery terminals need to slide inside the cover first. Then compress the triggers slightly, Then the cover will be aligned correctly. Then add the front cover and add screws so it doesn’t come undone.
    hunteil - Replica
  7. Pull the joysticks off of the controller.
    • Pull the joysticks off of the controller.
    Are the joystick potentiometers soldered to the mother board or just push fit, this guide doesn’t mention soldering so I’m assuming the latter?
    Can you get genuine replacement joystick potentiometers as I’ve only seen cheap eBay type ones?
    Alan - Replica
Conclusione
Altre 79 persone hanno completato questa guida.
Dylan Gross
Membro da: 25/09/2017
3.401 Reputazione
4 Guide realizzate
Cal Poly, Team S18-G3, Forte Fall 2017 Membro di Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 Membri
7 Guide realizzate
How about the square thing with the stick and hinges that the joystick is attached to? I think it’s called the Module. I have a joystick drift / drifting problem and that may help me out. Thanks.
Cory C - Replica
Agreed. That’s actually the part I need to replace too. The module.
Thomas Tomchak -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 150
Ultimi 30 Giorni: 770
Tutti i Tempi: 22,515
