Salta al contenuto principale
Xbox One Wireless Controller D-Pad Replacement
Cosa ti serve
  1. Xbox One Wireless Controller D-Pad Replacement, Battery Pack: passo 1, immagine 1 di 1
    • Remove the battery pack cover.
    • Remove batteries.
  2. Xbox One Wireless Controller D-Pad Replacement, Side Handles: passo 2, immagine 1 di 2 Xbox One Wireless Controller D-Pad Replacement, Side Handles: passo 2, immagine 2 di 2
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Start prying the side plate off underneath the trigger, this makes it easier to disconnect the other clips connecting the side plate to the backplate.
    Brandon - Replica
    One you take it off, is it possible to click it back in?
    Aiden Bear - Replica
    As long as you don’t exceed the couple tons you need to take it off you should be able to put it back.
    Brandon -
    I don’t have a squdger
    TimidFerret4982 Gaming - Replica
    getting those handles back on seems impossible, they just dont fit as well, a gap remains even after snapping into place.
    Dont think ill be doing this in the future
    Spoutin Wyze - Replica
    edit: wiggled the bo9ttom middlewith the handles off and somethign finally “clicked” into place for that extra 1/4 mm for the down arrow on my D-Pad to click back up into place!.
  3. Xbox One Wireless Controller D-Pad Replacement, Screws: passo 3, immagine 1 di 2 Xbox One Wireless Controller D-Pad Replacement, Screws: passo 3, immagine 2 di 2
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    i damaged my screws. how do i get the screws out?
    tenzin - Replica
    wait. i just watched a video guide on ifixit's youtube channel about damaged screws. i'll try those methods.
    tenzin - Replica
    It's a t8 or t9 security bit btw, I got the top two out with a regular T8, but the bottom two and middle needed a T9 Security bit.
    David Loper - Replica
    All five faceplate/backplate screws in the controller I disassembled were T8 security fasteners.
    John Dziedzic - Replica
    Am I doing something wrong because I got the tool it said I needed and got the middle screw out but the others have a bump or something in the center of the screw and it won't fit.
    kolton77 - Replica
    The T8 is only good for the middle screw on my One S controller. The others require something bigger
    Matej Skelo - Replica
    These requires SECURITY Torx bits (they have a cannulated hole in the driver). I don't believe the iFixIt branded driver is cannulated but you can buy a set of bits from DeWalt DWAX200 which is overkill but has what you need.
    jhighsmith - Replica
    The driver that iFixIt sells is cannulated.
    jhighsmith -
    where do you get this dumb ass screw driver
    Jake Zweier - Replica
    iFixit Store #IF145-027-3
    VauWeh - Replica
    You can bypass it with a 1.5mm flathead.
    Marianne Sandling - Replica
    thank you for this. worked for me
    Mr Anderson (Evolluisionist) -
    These screws required a T10, not T8.
    Armand - Replica
    TR9. A $10 kit from Walmart has the bit/driver in it and extra goodies to make life simple.
    Matt Martin - Replica
    As weird as it sounds, the top 2 came out for me with a flathead- but the bottom two and the middle one wont
    macybrooksevans - Replica
    If you damage the middle part of the screws you can still take it out with the same screwdriver.
    Kev God - Replica
    Thank-You :)
    Isaiah - Replica
    needed a T8H, not easy to see.
    on a grey green xbox one controller
    Michael - Replica
    On my 1708 controller there are two internal screws near the rumble motors that need to be removed with a T6 non security bit to remove the back cover.
    teeedubb - Replica
  4. Xbox One Wireless Controller D-Pad Replacement, Backplate: passo 4, immagine 1 di 1
    • Remove the backplate.
  5. Xbox One Wireless Controller D-Pad Replacement, Faceplate: passo 5, immagine 1 di 1
    • Remove the faceplate.
  6. Xbox One Wireless Controller D-Pad Replacement, Metal Frame: passo 6, immagine 1 di 2 Xbox One Wireless Controller D-Pad Replacement, Metal Frame: passo 6, immagine 2 di 2
    • Pry off the metal frame around the D-Pad.
  7. Xbox One Wireless Controller D-Pad Replacement, D-Pad: passo 7, immagine 1 di 1
    • Lift the D-Pad out of its housing.
Conclusione
Altre 44 persone hanno completato questa guida.
Garrett George
Membro da: 01/22/15
6.154 Reputazione
3 Guide realizzate
Cal Poly, Team 20-15, Maness Winter 2015 Membro di Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membri
50 Guide realizzate
7 Commenti
Can you show me how to replace xbox one controller 3.5mm stereo jack dpad
Arief Hidayat - Replica
This model of the xbox one controller does not feature a 3.5mm headphone jack. Please look at the guides for later models of the xbox one controller.
Brandon -
it's exactly the same like shown above :)
David Schmidt - Replica
How do u fix one of the silver things behind the d-pad?
Bob - Replica
How do fix the silver things behind each d-pad
Bob - Replica
I had a unresponsive left-button on my D-pad. It worked consistently only if I pressed very hard. l fixed mine, not with a new D-pad, but by adding a few layers of plastic tape over the press-sensitive “cushion” (the one that the button plastic part of the left d-pad should trigger). That made it much more responsive. It feels slightly different pressing down on the button now, but I can live with that trade-off.
john lastson - Replica
Como arreglo las teclas además de desmontar se puede arreglar cada botón?
isaac barreto - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 305
Tutti i Tempi: 63,102
