Salta al contenuto principale
Introduzione
This replacement guide is based on the Xbox Series S Model 1914 controller. There are certain situations where the joystick caps on the controller could become very sticky and/or become hard to move. That’s why it is important to change them or clean them every once in a while. That is what I’ll be explaining in the guide.
Ricambi
Nessuna parte specificata.
  1. Xbox One Wireless Controller (Model 1914) Joystick Caps Replacement, Joystick Caps: passo 1, immagine 1 di 3 Xbox One Wireless Controller (Model 1914) Joystick Caps Replacement, Joystick Caps: passo 1, immagine 2 di 3 Xbox One Wireless Controller (Model 1914) Joystick Caps Replacement, Joystick Caps: passo 1, immagine 3 di 3
    • Open the back of controller by sliding the battery cover upwards.
    • Remove the batteries from the controller.
  2. Xbox One Wireless Controller (Model 1914) Joystick Caps Replacement: passo 2, immagine 1 di 2 Xbox One Wireless Controller (Model 1914) Joystick Caps Replacement: passo 2, immagine 2 di 2
    • Use an opening tool to pry both side plates open.
  3. Xbox One Wireless Controller (Model 1914) Joystick Caps Replacement: passo 3, immagine 1 di 2 Xbox One Wireless Controller (Model 1914) Joystick Caps Replacement: passo 3, immagine 2 di 2
    • Punch a hole in the center of the sticker to find hidden screw. Then remove the screws with the Torx TR9 screwdriver.
    • All the the screws are the same length so they are all interchangeable for each of the five spots when screwing them out.
  4. Xbox One Wireless Controller (Model 1914) Joystick Caps Replacement: passo 4, immagine 1 di 1
    • Remove the front plate of controller.
  5. Xbox One Wireless Controller (Model 1914) Joystick Caps Replacement: passo 5, immagine 1 di 1
    • Pull the joysticks off the controller to either clean them or replace them.
Conclusione
Kyjuan Cannady
Membro da: 05/10/2021
124 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 117
Tutti i Tempi: 620
