Introduzione
So you've confirmed your Xbox One S cannot connect to any Wi-Fi sources, but other devices can. Follow these steps to replace the Wi-Fi card.
Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
Important!!
You've to start from the back corner where is the information label, because there is a main clip behind a warranty sticker
They should add this to the guide! I didnt know that, and did some minor damage to the bottom piece where that main clip is.
I dont mind because it's my own Xbox, but what if it belonged to a customer?
Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
Do not remove the back panel from the metal housing by popping loose the “rivets” in Step 5 photo. Those are not rivets, they are melted post-end mounts in which the heads will break off and CAN NOT BE REPLACED by the do-it-yourself repairer (unless you want to try hot gluing the mounts back to the panel, but success is uncertain with this method). While doing my own tear-down following the photo examples, I thought the rear panel was meant to come off due to the photo of it laying next to the body in Step 7. This is inaccurate, and will most likely result in a loose fitting panel upon reassembly. The “rivets” no longer have a means to hold onto the metal body tray they came loose from. So you will have the panel relying on alignment back to the channel the tabs came out of in order to hold it to the back of your machine. Other than this issue, I was able to perform the tear-down without problem.
Gently separate the interior case from the white exterior case using the appropriate method.
Search the sides of the interior case for the Wi-Fi card. It should be across from the hard drive.
Remove the black T8 screws with orange circles around them (there should be 3 of them).
After removing the screws, gently detach the Wi-Fi card.
These are T8 screws. If you’re surprised by that, having only seen a T10 in the parts list for this fix, that makes two of us :(
Altre 15 persone hanno completato questa guida.
3 Commenti
T8 Torx Bit Screwdriver
