Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
The power block's connector to the motherboard is difficult to disconnect by hand initially. While unnecessary, we highly recommend removing the motherboard from the silver casing first to access the power block's connector.
  1. Flip the Xbox One S so that the bottom of the case is facing upward.
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Insert the plastic opening tool into the  gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
    • Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at one corner and sliding the prying tool along the edges of the Xbox One S. Once the first few clips are opened you can lift the cover up to find the remaining clips.
  3. Once all of the clips are opened, remove the bottom part of the case.
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Find all of the green screws on the metal case labeled F1 through F6. Take the T10 Torx screwdriver and remove the six 50 mm long screws.
    • Find all of the green screws on the metal case labeled F1 through F6.
    • Take the T10 Torx screwdriver and remove the six 50 mm long screws.
  5. Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal. This step is necessary because you need to pry interior rivets away from the exterior case. The interior rivets that that hold the case in place are circled in the last image. After you gently pry in the areas demonstrated, the side panel of the exterior case will be able to come off of the rest of the casing. Look at the image in Step 7 for clarification on how the exterior case disassembles.
    • Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
    • This step is necessary because you need to pry interior rivets away from the exterior case. The interior rivets that that hold the case in place are circled in the last image. After you gently pry in the areas demonstrated, the side panel of the exterior case will be able to come off of the rest of the casing.
    • Look at the image in Step 7 for clarification on how the exterior case disassembles.
  6. Gently separate the interior case from the white exterior case using the appropriate method. Gently separate the interior case from the white exterior case using the appropriate method.
    • Gently separate the interior case from the white exterior case using the appropriate method.
  7. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Acquista ora
    Acquista ora
  8. To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S. This will allow the plastic casing surrounding the hard drive to become detached from  the rest of the console.
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
  9. Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies). Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies). Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
  10. To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C5."
    • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C5."
  11. Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
    • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
  12. To replace the motherboard you must remove the three silver 10 mm T-10 Torx screws labelled "C1," "C2," and "C6."
    • To replace the motherboard you must remove the three silver 10 mm T-10 Torx screws labelled "C1," "C2," and "C6."
    • Remove the four black 8 mm T-9 Torx screws lablelled "A1," "A2," "A3," and "A4."
  13. Locate the rectangular silver clamp on the opposite corner of the power block.
    • Locate the rectangular silver clamp on the opposite corner of the power block.
  14. Grab the clamp with the tweezers. Pull the clamp upward, away from the silver casing. Jiggle it back and forth like a tooth if necessary.
    • Grab the clamp with the tweezers. Pull the clamp upward, away from the silver casing. Jiggle it back and forth like a tooth if necessary.
    • It's okay to apply a little bit of force here to get the clamp off the silver casing. The metal is bendable and can be bent/clamped back on.
  15. Now that the clamp is removed, gently lift the motherboard from its edges out from the metal casing. The motherboard should come out with ease.
    • Now that the clamp is removed, gently lift the motherboard from its edges out from the metal casing. The motherboard should come out with ease.
  16. Gently lift the power block off the motherboard
    • Gently lift the power block off the motherboard
  17. Locate the black connector that joins the power block to the motherboard.
    • Locate the black connector that joins the power block to the motherboard.
    • The protruding rectangular part of the plastic connector, shown by the orange marker, is a locking tab.
  18. Grab the connector as shown, pinch the small black locking tab, and pull firmly upward to detach the power block from the motherboard .
    • Grab the connector as shown, pinch the small black locking tab, and pull firmly upward to detach the power block from the motherboard .
Conclusione
Altre 20 persone hanno completato questa guida.
Erik Ramazzini
Membro da: 26/04/2017
1.472 Reputazione
3 Guide realizzate
Cal Poly, Team S22-G3, Livingston Spring 2017 Membro di Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 Membri
33 Guide realizzate
So my Xbox One S isn’t turning on at all. No light, nothing. I went to take it apart and I plugged it in just to see if it would boot out of the blue. I turned it on and nothing happened but I can hear a faint clicking sound from the power supply. Does that mean, the power supply has gone bad, and I’ll need to replace it?
Cyology.IO - Replica
yes because this xbox one s internal power supply is a fail.. look at there newer model the “xbox one x “ the internal powersupply of it has air ventilation coming from the upgraded version of the fan.
meaning the xbox one s power supply has no proper ventilation no air that blow the exhaust the heat will stuck up inside .. thats why it will not last longer .
the worst is that its design it self .. imagine when you accidentaly pour a water into the fan .. the water will go directly to the cpu and mobo.
that is why they upgrade the “xbox one x“ they copied the design from the ps4 that the air ventilation is on the side panels..
Michael Creech - Replica
My xbox one s stopped working after a power surge from a string of storms. It wont respond, make any noise at all. I figured i would replace the power supply and see if that’s the fix. While i’m waiting for the part to arrive, i’m wondering if there is any other damage that could’ve been done by the surge. Or does the power supply prevent that?
quintalnick - Replica
did you ever get that storm Xbox to work? I just lost mine to a storm last night :(
Adam Portugali -
my one s is working fine all apps are good my network connection is goood its cleaned and maintenanced properly all is working well until i try doing the one thing i bought it for playing games doesnt matter if its disc or downloaded soon as it loads and im ready to play the console crashes to no signal and shuts off
spanky8623 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 40
Ultimi 7 Giorni: 255
Ultimi 30 Giorni: 1,311
Tutti i Tempi: 42,563
