Salta al contenuto principale
Xbox One S All Digital Edition Plastic Enclosure Replacement
Cosa ti serve
  1. Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: passo 1, immagine 1 di 3 Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: passo 1, immagine 2 di 3 Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: passo 1, immagine 3 di 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Plastic Enclosure Replacement: passo 2, immagine 1 di 2 Xbox One S All Digital Edition Plastic Enclosure Replacement: passo 2, immagine 2 di 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Plastic Enclosure Replacement: passo 3, immagine 1 di 2 Xbox One S All Digital Edition Plastic Enclosure Replacement: passo 3, immagine 2 di 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Plastic Enclosure Replacement: passo 4, immagine 1 di 1
    • Flip the metal enclosure so that the fan cover is on top.
Conclusione
Jules Hajjar
Membro da: 10/10/19
1.915 Reputazione
8 Guide realizzate
Cal Poly, Team S12-G6, Regan Fall 2019 Membro di Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Membri
32 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 106
Tutti i Tempi: 3,630
