Salta al contenuto principale
Xbox One Kinect LED Sensor Replacement
Cosa ti serve
  1. Xbox One Kinect LED Sensor Replacement, Outer Shell: passo 1, immagine 1 di 1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. Xbox One Kinect LED Sensor Replacement: passo 2, immagine 1 di 3 Xbox One Kinect LED Sensor Replacement: passo 2, immagine 2 di 3 Xbox One Kinect LED Sensor Replacement: passo 2, immagine 3 di 3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
    Chiedi a FixBot
    Aggiungi Commento
  3. Xbox One Kinect LED Sensor Replacement: passo 3, immagine 1 di 3 Xbox One Kinect LED Sensor Replacement: passo 3, immagine 2 di 3 Xbox One Kinect LED Sensor Replacement: passo 3, immagine 3 di 3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
    Chiedi a FixBot
    Aggiungi Commento
  4. Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: passo 4, immagine 1 di 3 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: passo 4, immagine 2 di 3 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: passo 4, immagine 3 di 3
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team 1-3, Hickman Fall 2014 Membro di USF Tampa, Team 1-3, Hickman Fall 2014
USFT-HICKMAN-F14S1G3
4 Membri
7 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 34
Tutti i Tempi: 1,533
