Introduzione
The hard drive stores game data and user profiles. During game installation, most of the game data from the disc is copied onto the hard drive so the game launches faster, plays smoother, and can be modified later.
The complete removal of the optical drive is not necessary for this, although the steps leading up to it are.
Cosa ti serve
Slide the black angled tab behind the silver button toward the back of the console and set it aside.
Remove all eight of the 64.0 mm, T-9 screws labeled C1 through C8 securing the chassis top to the motherboard.
Lift the bottom half of the chassis (motherboard and all) from the bottom half of the black case.
Unplug the red wire connecting the optical drive to the motherboard from its connector on the motherboard.
Unplug the yellow wire connecting the optical drive to the motherboard from its connector on the motherboard.
The optical drive is now free, lift it from the chassis and set it aside.
Unplug the red wire connecting the hard drive to the motherboard from its connector on the motherboard.
Unplug the multi-colored wire connecting the hard drive to the motherboard from its connector on the motherboard.
The hard drive is now free, remove it from the chassis by lifting straight up. Set it aside.
Altre 12 persone hanno completato questa guida.
Un commento
Do you possibly have a list of the relevant files that should be on the new hard drive? I put mine back it, did the whole plug in ethernet and let it sit, nothing. tried flashing update, nothing. factory reset file, E200 so i pulled it back apart and am looking at the file set up on my desktop trying to determine if there are any missing files. any help is appreciated.
