Salta al contenuto principale
Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement
Cosa ti serve
    1. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement, Controller Button and Trigger: passo 1, immagine 1 di 2 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement, Controller Button and Trigger: passo 1, immagine 2 di 2
      • Remove the seven screws from the back of the controller using a Phillips #1 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 2, immagine 1 di 3 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 2, immagine 2 di 3 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 2, immagine 3 di 3
      • Place an opening tool between the front and rear controller panels at the bottom of the controller.
      • Pry the bottom of the controller open around the audio port.
      • The controller might make a loud click; that is okay.
      Chiedi a FixBot
      Aggiungi Commento
    3. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 3, immagine 1 di 2 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 3, immagine 2 di 2
      • Remove both screws on the back of the motherboard under the triggers using a Phillips #1 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    4. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 4, immagine 1 di 3 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 4, immagine 2 di 3 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 4, immagine 3 di 3
      • Place your left hand at the base of the motherboard and your right hand on the frame.
      • Lift the motherboard up from the pegs that hold it in place.
      • The motherboard will still be connected to the controller once off the pegs.
      • Do not try to force the motherboard out after getting it off the pegs.
      • Pull down gently to remove the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    5. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 5, immagine 1 di 2 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 5, immagine 2 di 2
      • Under each trigger is a small guard rail that needs to be pushed in order to get to the screws for the trigger.
      • Push the rail towards the motherboard to free the triggers to get to the screws.
      Chiedi a FixBot
      Aggiungi Commento
    6. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 6, immagine 1 di 1
      • Remove the two screws from each of the triggers (four total) using a Phillips #1 screwdriver.
      • The triggers will fall out when unscrewed.
      Chiedi a FixBot
      Aggiungi Commento
    7. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 7, immagine 1 di 3 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 7, immagine 2 di 3 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 7, immagine 3 di 3
      • Replace each of the triggers by screwing them back together.
      • Push the rail back onto the trigger peg.
      • The motherboard is done until reassembly.
      Chiedi a FixBot
      Aggiungi Commento
    8. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 8, immagine 1 di 2 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 8, immagine 2 di 2
      • Remove the two screws from the top bumper board using a Phillips #1 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    9. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 9, immagine 1 di 2 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 9, immagine 2 di 2
      • Pull up on the bumper board to remove it.
      Chiedi a FixBot
      Aggiungi Commento
    10. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 10, immagine 1 di 2 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 10, immagine 2 di 2
      • Pick up the circuit board to remove it from the base.
      • The circuit board is loose and might fall out in Step 9.
      Chiedi a FixBot
      Aggiungi Commento
    11. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 11, immagine 1 di 2 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 11, immagine 2 di 2
      • Remove the rubber button cover.
      Chiedi a FixBot
      Aggiungi Commento
    12. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 12, immagine 1 di 2 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 12, immagine 2 di 2
      • Remove the inner buttons.
      Chiedi a FixBot
      Aggiungi Commento
    13. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 13, immagine 1 di 2 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: passo 13, immagine 2 di 2
      • Replace each of the buttons.
      • Each of the buttons have pegs that will help you line them up in the correct location and orientation.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
6Commenti sulla guida
Can you tell me where i can get the exact same circuit board for this controller i would greatly appreciate it if you respond!
ismaeel - Rispondi Condividi
Just look on ebay broken electronic's and you can fine several of these I have several controllers on ebay for 5 dollars each myself (they all work)
Zachary Marcotte - Rispondi Condividi
I took my controller apart up to step 4 in order to reseat the analog stick sensors to help with stick drift and this guide helped me check my work to make sure I hadn't missed anything and was doing it properly. The pictures were quite handy.
I think it would be good to add that there's a pin array attached to the second circuit board with the bumpers that you need to re socket when putting the controller back together. The controller mostly works even without the pins in place, but the Y button is connected to one of these pins and will not work unless the pins are properly socketed, I had to disassemble and reassemble my controller a second time after realising this, but once I got it done with the pins in the right place it worked as desired. It's entirely possible and maybe even likely you'll bend the pins on the secondary board during initial disassembly (I had), but it's easy to simply set them back upright, just don't lose the pin guide!
Jay Denney - Rispondi Condividi
We didn't really have that problem, it is good to know though. We did this project as a technical level writing class so we won't be doing any updates. I am glad it helped you.
Where can I get a replacement rubber button cover? My 'A' button is getting stuck down because the rubber cap is worn out.
Alec Heasley - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 58
Ultimi 30 giorni: 217
Tutti i Tempi: 9,209
