Salta al contenuto principale
Xbox Hard Drive Management
Cosa ti serve
  1. Xbox Hard Drive Management, Xbox Hard Drive Management: passo 1, immagine 1 di 1
    • Boot up your Xbox without a disc in the drive and you will get the dashboard. Head to "Memory", as the Xbox doesn't have a single format HD option.
  2. Xbox Hard Drive Management: passo 2, immagine 1 di 1
    • Here you can see the Xbox hard drive options. Select the save you want to delete, and hit A.
  3. Xbox Hard Drive Management: passo 3, immagine 1 di 1
    • Press A to delete the save. Then go back and delete all the other saves you want to delete. Now your Xbox HD is completely clear of savegames.
    • If you're selling your Xbox, go to Settings and turn off auto-login and go to Xbox LIVE and remove your account options.
Conclusione
Make sure you haven't left any music on your Xbox HD if you're selling your Xbox.
Altre 20 persone hanno completato questa guida.
Eddie Meehan
Membro da: 09/23/13
894 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 61
Tutti i Tempi: 11,181
