Salta al contenuto principale
Introduzione
This guide will explain how to disassemble the Xbox DVD Drive in order to preform repairs or remove a stuck game by manually ejecting the drive.
  1. Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
    • Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
  2. Turn the Xbox over to reveal the four rubber feet.
    • Turn the Xbox over to reveal the four rubber feet.
    • Use a metal spudger to pry off the four rubber feet.
  3. There are 2 more screws hidden under the two labels on the bottom of the case. You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
    • There are 2 more screws hidden under the two labels on the bottom of the case.
    • You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
  4. Remove the six T20 Torx screws securing the top cover to the bottom cover.
    • Remove the six T20 Torx screws securing the top cover to the bottom cover.
  5. Wedge a metal spudger and carefully pry upwards to slightly separate the top and bottom covers. Flip the Xbox right side up.
    • Wedge a metal spudger and carefully pry upwards to slightly separate the top and bottom covers.
    • Flip the Xbox right side up.
    • Hold the sides and lift the Xbox slightly off the bench. A gentle shake of the unit should see the top cover separate from the rest of the unit quite easily.
    • Placing the Xbox on your lap while separating the top and bottom covers may make the process easier.
  6. Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover. Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
    • Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
  7. Remove the three 3 mm T10 screws securing the hard drive to the Xbox. There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up.  The other two are at the front right and left sides of the hard drive.
    • Remove the three 3 mm T10 screws securing the hard drive to the Xbox.
    • There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up. The other two are at the front right and left sides of the hard drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  8. Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out. Lift the plastic hard drive carrier out of the Xbox case.
    • Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
    • Lift the plastic hard drive carrier out of the Xbox case.
  9. Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side). Carefully remove the hard drive from the plastic carrier.  Gentle rocking will see the hard drive come out quite easily. Carefully remove the hard drive from the plastic carrier.  Gentle rocking will see the hard drive come out quite easily.
    • Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
    • Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
  10. Pull both the hard drive data  ribbon cable and the power cable straight up from the hard drive. They may be firmly seated, so be careful trying to remove them.  DO NOT pull the wires as you may damage the cable assembly.
    • Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
    • They may be firmly seated, so be careful trying to remove them. DO NOT pull the wires as you may damage the cable assembly.
  11. Remove the disk drive. It should come right out. Unplug the ribbon cable and yellow cables from back of disk drive. Unplug the ribbon cable and yellow cables from back of disk drive.
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
  12. Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
    • ONLY REMOVE IF DEAD!
  13. Please note that if all you are trying to do is manually eject a game and not make repairs to the drive, step 14 is the ONLY required step. It is NOT necessary to remove the drives casing, just push the tray in when you're done. Start by removing the 4 screws on the bottom of the drives case using a Philips #0. There are different variations of the drive and some have Torx screws instead of Philips. Use the necessary tool for the specific version that you have. Once screws are removed, lift the bottom half of the case up and away from the drive.
    • Please note that if all you are trying to do is manually eject a game and not make repairs to the drive, step 14 is the ONLY required step. It is NOT necessary to remove the drives casing, just push the tray in when you're done.
    • Start by removing the 4 screws on the bottom of the drives case using a Philips #0. There are different variations of the drive and some have Torx screws instead of Philips. Use the necessary tool for the specific version that you have.
    • Once screws are removed, lift the bottom half of the case up and away from the drive.
    • Flip the drive over and remove the top half of the drives case.
  14. Using your screwdriver, or anything slim enough to fit, gently push the white lever back. Put your object on the right hand side of the lever, slightly pushing right as you push back. The lens will drop down and your drive door will open about a quarter inch. Gently pull the tray to its open position. If you have a game stuck in your drive, this would be the ideal time to remove it. It can be removed in step 13 but it's not as easy.
    • Using your screwdriver, or anything slim enough to fit, gently push the white lever back. Put your object on the right hand side of the lever, slightly pushing right as you push back.
    • The lens will drop down and your drive door will open about a quarter inch.
    • Gently pull the tray to its open position. If you have a game stuck in your drive, this would be the ideal time to remove it. It can be removed in step 13 but it's not as easy.
  15. Gently push the tray closed by hand.
    • Gently push the tray closed by hand.
    • Using your screwdriver, or whatever object best suits you, you need to return the white lever to its forward position to reset the drive properly. Get your object behind the right side of the lever, gently pushing it forward, returning it to its original position.
  16. Put the top of the case on first and then flip the drive.
    • Put the top of the case on first and then flip the drive.
    • Replace the bottom half of the case and secure the screws back in place.
Conclusione
To reassemble your device, follow these instructions in reverse order STARTING FROM STEP 12.
Altre 2 persone hanno completato questa guida.
Navy Vet 2015
Membro da: 25/06/2015
3.983 Reputazione
11 Guide realizzate
What is the easiest way to clean the laser in the original xbox?
Brayan Hernandez - Replica
Hit it with a can of air duster. If further cleaning is required apply a small amount of rubbing alcohol on a Q-tip and gently clean the lens. I hope this helps.
Navy Vet 2015 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 195
Tutti i Tempi: 8,694
