Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Xbox Adaptive Controller, usa il nostro manuale di assistenza.
  1. Xbox Adaptive Controller Teardown, Xbox Adaptive Controller Teardown: passo 1, immagine 1 di 1
    • Designed to bring accessible gaming to Xbox One consoles and Windows 10 PCs, this unique controller is big on possibilities, not specs. Here's what we know:
    • Nineteen 3.5mm ports, two USB 2.0 ports, one USB-C port, and one 3.5 mm stereo headset jack
    • Xbox Wireless Bluetooth
    • AMPS and tripod mount compatibility
    • Rechargeable Li-Po battery
    • 292 mm (L) x 130 mm (W) x 23 mm (H)
    Chiedi a FixBot
  2. Xbox Adaptive Controller Teardown: passo 2, immagine 1 di 3 Xbox Adaptive Controller Teardown: passo 2, immagine 2 di 3 Xbox Adaptive Controller Teardown: passo 2, immagine 3 di 3
    • Packaging designed to be super easy to open. Lovely big handles for lifting out the tray containing the hardware.
    Chiedi a FixBot
  3. Xbox Adaptive Controller Teardown: passo 3, immagine 1 di 3 Xbox Adaptive Controller Teardown: passo 3, immagine 2 di 3 Xbox Adaptive Controller Teardown: passo 3, immagine 3 di 3
    • Comparison to regular Xbox One controller (we're still rocking our Day One Edition)
    • Not as many buttons/functions to be sure, but this is wayyyy more configurable.
    • A total of nineteen "3.5 mm connection ports" line the backside of this controller. These allow for a virtually limitless number of ways to play.
    • Some of these are digital, some are analog, and some are both! Microsoft was nice enough to lay it all out for users in these two guides.
    • "Switches... allow people with limited mobility to control a game using different parts of their body, like their head, foot, or mouth. But switches, typically made by medical supply companies, can be expensive—up to $200 apiece—and clunky." -wired
    • Hello from Seattle! Model 1836. Also, three threaded mounting points so you can secure this thing however you need.
    Chiedi a FixBot
  4. Xbox Adaptive Controller Teardown: passo 4, immagine 1 di 3 Xbox Adaptive Controller Teardown: passo 4, immagine 2 di 3 Xbox Adaptive Controller Teardown: passo 4, immagine 3 di 3
    • Four rubber feet conceal some screws. T9 Torx Security! Security screws are not our cup of tea, but we're armed and ready with the right driver for the occasion.
    • Decorating the inside case, we spy what appears to be... a honey badger. Microsoft products are known to conceal the occasional Easter egg, but we're unsure what to make of this one!
    Chiedi a FixBot
  5. Xbox Adaptive Controller Teardown: passo 5, immagine 1 di 3 Xbox Adaptive Controller Teardown: passo 5, immagine 2 di 3 Xbox Adaptive Controller Teardown: passo 5, immagine 3 di 3
    • Battery doesn't take up much space b/c this controller is huge
    • Battery specs:
    • 7.79 Wh Li-Po battery
    • Potential comparison to the 2 AA batteries in the Xbox One controller.
    • Modular headphone jack! Neat.
    • Other ports looking not so modular—let's explore further
    Chiedi a FixBot
  6. Xbox Adaptive Controller Teardown: passo 6, immagine 1 di 3 Xbox Adaptive Controller Teardown: passo 6, immagine 2 di 3 Xbox Adaptive Controller Teardown: passo 6, immagine 3 di 3
    • Separating main board from plastic housing... more screws! Twelve more Torx security screws and one lone Philips.
    • Very simple construction here, and only the one board. It's a little unfortunate that so many ports are soldered down/difficult to service—but there's so much redundancy with those nineteen accessory ports, maybe it's not a big deal? (Provided you don't need all 19 of course.) It helps that button functions can also be remapped in software.
    • Just a few chips in this sea of green:
    • A Microsoft-branded ARM chip labeled X905893-002
    • This is more than likely the MCU. One person claims this same chip is in the Xbox One controllers (the 1708 variety).
    • Texas Instruments BQ24250 2 A Li-ion battery charger w/ power-path management
    • FTDI Vinculum-II programmable USB 2.0 host
    • NXP PCAL6524 I/O expander
    Chiedi a FixBot
  7. Xbox Adaptive Controller Teardown: passo 7, immagine 1 di 3 Xbox Adaptive Controller Teardown: passo 7, immagine 2 di 3 Xbox Adaptive Controller Teardown: passo 7, immagine 3 di 3
    • Button thoughts: a lot of the switches and buttons available in tandem with this controller have a very specific amount of travel, or take a certain amount of force to toggle. There was probably a lot of thought put into the way that each of these buttons (particularly the A and B buttons) click.
    • The action on all of the buttons is very tactile. There are no rubber gaskets to dampen any of the switches—even the ones on the D-pad!
    • The A and B buttons have the least resistance, and are the only buttons that do not press directly onto a switch on the motherboard.
    • Plastic button covers & Spring mechanisms
    Chiedi a FixBot
  8. Xbox Adaptive Controller Teardown: passo 8, immagine 1 di 1
    • This Adaptive Controller is definitely a simple machine at first blush, but it's easy to tell that Microsoft put a lot of thought into it, from the minute you open the box.
    • ... If only they made it as easy to open the controller itself? We can forgive the hiding of screws under the rubber feet, but the liberal use of T9 and T6 Torx security screws here is less than ideal.
    • There aren't many moving parts when compared to your standard controller—which means fewer points of failure—but each of the button switches and the majority of the 3.5 mm ports are soldered directly to the motherboard. So should any of those fail, you're out $99.
    • Speaking of those soldered-on 3.5 mm ports: while it's a bummer they're all stuck to the main board, it's nice to see Microsoft stick with what appears to be the standard port for these assistive gaming accessories. Most of the popular switches, buttons, and toggles all appear to be plug-n-play ready.
    Chiedi a FixBot
  9. Considerazioni finali
    • Disassembly is straightforward, nondestructive, and easily reversible.
    • Primary components are secured with screws; no adhesive in sight.
    • The battery is rechargeable, modular, and can be replaced after removing just four screws.
    • A portion of the components are modular and can be replaced, but some high-wear parts (like 3.5 mm ports and the springy A and B button covers) will require specials tools to repair should they break.
    • Use of Torx security screws creates an unnecessary repair hurdle.
    Punteggio di riparabilità
    7
    Riparabilità 7 su 10
    (10 è il più facile da riparare)
1Commento della guida
thank you for sharing this
Boglarka Zs. Lengyel - Rispondi Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 150
Tutti i Tempi: 4,665
