Salta al contenuto principale
Introduzione
Getting dead-zone drift? If you've dropped the controller, threw it at a wall in a post-loss rage, or pressed too hard during your epic gaming session, your D-pad may be broken. This is a guide to replace the D-pad.
  1. Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller. Pull the two AA batteries out.
    • Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller.
    • Pull the two AA batteries out.
  2. Lift the battery compartment out of the controller and set it outside of the controller. Do not yank, stress, or pull on the wires for removal. Use the precision tweezers to pull out the red and black wire attached to the white plug at the bottom side of the circuit board.
    • Lift the battery compartment out of the controller and set it outside of the controller.
    • Do not yank, stress, or pull on the wires for removal.
    • Use the precision tweezers to pull out the red and black wire attached to the white plug at the bottom side of the circuit board.
  3. Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw. Use a T6 Torx screwdriver to remove the 1.5mm screw.
    • Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw.
    • Use a T6 Torx screwdriver to remove the 1.5mm screw.
  4. Insert a spudger and pry at these three locations to detach the middle cover. Pull off the middle piece cover to reveal three screws. Use a T8 Torx screwdriver to remove the three 2.3mm screws.
    • Insert a spudger and pry at these three locations to detach the middle cover.
    • Pull off the middle piece cover to reveal three screws.
    • Use a T8 Torx screwdriver to remove the three 2.3mm screws.
    • Remove the cover.
  5. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  6. Remove the two 90mm screws with a T8 Torx screwdriver. Lift up the silver middle piece to remove. Lift up the silver middle piece to remove.
    • Remove the two 90mm screws with a T8 Torx screwdriver.
    • Lift up the silver middle piece to remove.
  7. Use a spudger to remove the silver prong. With the spudger, pinch the metal spring and slowly pull up to remove. Use the spudger to remove eject button.
    • Use a spudger to remove the silver prong.
    • With the spudger, pinch the metal spring and slowly pull up to remove.
    • Use the spudger to remove eject button.
    • Remove the screw holding in the eject button with a T8 Torx screwdriver.
  8. This step is very difficult and may require a third hand. Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together. Start with one side of the controller (left or right).
    • This step is very difficult and may require a third hand.
    • Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together.
    • Start with one side of the controller (left or right).
    • Slide the spudger towards the end of the handles and pry the two halves apart. Do the same for the opposite side.
    • The white circular caps at the top of the controller will pop off by applying light force.
    • Pull the front and back panels apart to separate them and expose the inside of the controller.
  9. Use precision tweezers to remove the red and black wires that are attached to the circuit board. The rumble motors will easily  lift out of the controller once the wires are detached.
    • Use precision tweezers to remove the red and black wires that are attached to the circuit board.
    • The rumble motors will easily lift out of the controller once the wires are detached.
  10. Use a T6 Torx screwdriver to remove the four 2.3mm screws. Lift up the black locking tab on the ZIF connector to release the ribbon cable. Lift up the black locking tab on the ZIF connector to release the ribbon cable.
    • Use a T6 Torx screwdriver to remove the four 2.3mm screws.
    • Lift up the black locking tab on the ZIF connector to release the ribbon cable.
  11. Lift up the trigger to remove it from the controller.
    • Lift up the trigger to remove it from the controller.
    • The trigger is made up of three pieces: the trigger, a circuit board, and a ribbon cable.
    • Repeat for the other trigger.
  12. Remove the grey silicone pad on the right side to expose the backside of the D-pad. Remove the two screws with a T6 Torx screwdriver. Remove the two screws with a T6 Torx screwdriver.
    • Remove the grey silicone pad on the right side to expose the backside of the D-pad.
    • Remove the two screws with a T6 Torx screwdriver.
  13. Lift and remove the black, plastic backing of D-pad. The front of the D-pad will detach as you pull the back off.
    • Lift and remove the black, plastic backing of D-pad. The front of the D-pad will detach as you pull the back off.
Conclusione
lauren paganella
Membro da: 15/02/2018
399 Reputazione
4 Guide realizzate
USF Tampa, Team S16-G5, Boczar Spring 2018 Membro di USF Tampa, Team S16-G5, Boczar Spring 2018
USFT-BOCZAR-S18S16G5
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 102
