Salta al contenuto principale
Xbox 360 Wireless Speed Wheel Back Panel Replacement
Cosa ti serve
  1. Xbox 360 Wireless Speed Wheel Back Panel Replacement, Battery: passo 1, immagine 1 di 2 Xbox 360 Wireless Speed Wheel Back Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller.
    • Pull the two AA batteries out.
  2. Xbox 360 Wireless Speed Wheel Back Panel Replacement, Back Panel: passo 2, immagine 1 di 2 Xbox 360 Wireless Speed Wheel Back Panel Replacement, Back Panel: passo 2, immagine 2 di 2
    • Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw.
    • Use a T6 Torx screwdriver to remove the 1.5mm screw.
  3. Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 3, immagine 1 di 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 3, immagine 2 di 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 3, immagine 3 di 3
    • Insert a spudger and pry at these three locations to detach the middle cover.
    • Pull off the middle piece cover to reveal three screws.
    • Use a T8 Torx screwdriver to remove the three 2.3mm screws.
    • Remove the cover.
  4. Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 4, immagine 1 di 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 4, immagine 2 di 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 4, immagine 3 di 3
    • Remove the two 90mm screws with a T8 Torx screwdriver.
    • Lift up the silver middle piece to remove.
  5. Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 5, immagine 1 di 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 5, immagine 2 di 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 5, immagine 3 di 3
    • Use a spudger to remove the silver prong.
    • With the spudger, pinch the metal spring and slowly pull up to remove.
    • Use the spudger to remove eject button.
    • Remove the screw holding in the eject button with a T8 Torx screwdriver.
  6. Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 6, immagine 1 di 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 6, immagine 2 di 3 Xbox 360 Wireless Speed Wheel Back Panel Replacement: passo 6, immagine 3 di 3
    • This step is very difficult and may require a third hand.
    • Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together.
    • Start with one side of the controller (left or right).
    • Slide the spudger towards the end of the handles and pry the two halves apart. Do the same for the opposite side.
    • The white circular caps at the top of the controller will pop off by applying light force.
    • Pull the front and back panels apart to separate them and expose the inside of the controller.
Conclusione
USF Tampa, Team S16-G5, Boczar Spring 2018 Membro di USF Tampa, Team S16-G5, Boczar Spring 2018
USFT-BOCZAR-S18S16G5
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 863
