Salta al contenuto principale
Xbox 360 Wireless Controller Buttons Replacement
Cosa ti serve
  1. Xbox 360 Wireless Controller Buttons Replacement, Battery: passo 1, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement, Battery: passo 1, immagine 2 di 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Buttons Replacement, Rear Case: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Buttons Replacement: passo 3, immagine 1 di 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller Buttons Replacement: passo 4, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement: passo 4, immagine 2 di 2
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Buttons Replacement: passo 5, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement: passo 5, immagine 2 di 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Buttons Replacement: passo 6, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement: passo 6, immagine 2 di 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Xbox 360 Wireless Controller Buttons Replacement, Vibration Motors: passo 7, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement, Vibration Motors: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller Buttons Replacement: passo 8, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement: passo 8, immagine 2 di 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  9. Xbox 360 Wireless Controller Buttons Replacement, Logic Board: passo 9, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement, Logic Board: passo 9, immagine 2 di 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  10. Xbox 360 Wireless Controller Buttons Replacement, Buttons: passo 10, immagine 1 di 1
    • Remove the rubber pad from the back of the input buttons.
  11. Xbox 360 Wireless Controller Buttons Replacement: passo 11, immagine 1 di 2 Xbox 360 Wireless Controller Buttons Replacement: passo 11, immagine 2 di 2
    • Using a pair of tweezers, remove the buttons from the front case.
    • A Button
    • B Button
    • X Button
    • Y Button
    • Start Button
    • Select Button
    • Guide Button
  12. Xbox 360 Wireless Controller Buttons Replacement: passo 12, immagine 1 di 1
    • Using a pair of tweezers, lift the home button's LED ring out of the front case of the controller.
    • All of the buttons have tabs that correspond to slots in the front case. This prevents buttons from being placed in the incorrect position or orientation.
Conclusione
Altre 65 persone hanno completato questa guida.
Brett Hartt
Membro da: 04/12/10
131.238 Reputazione
143 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.648 Guide realizzate
3Commenti sulla guida
Hello I have had an Xbox for about 1-2years and everything has been working fine until the A button on one of my controllers stopped working I don't think it has gunk or anything because I can press it down and it comes back up just that when I press it in screen nothing happens but the other buttons work fine
Saul Escalon - Replica
Thank you for the teardown! My cat has just vomitted on my joystick…. I could have cleaned it now! I appreciate it , thanks…
Nathan St-Onge - Replica
Has anyone ever replaced the spring contacts in the logic board???
BJ Robbins - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 163
Ultimi 30 Giorni: 523
Tutti i Tempi: 75,721
