Introduzione
This guide will explain how to remove the Hard Drive, take apart the Bottom Panel, and the Top Panel.
Cosa ti serve
Flip the Xbox over and you will see three separate prongs. Pull those back and pull up, then you will see the hard drive. Pull the rectangle fabric piece up.
The hard drive should be removed.
Move the Xbox with the hard drive facing toward the right.
Then insert your Metal Spudger in between the silver ring and the vent. You should here a pop noise which is the clip popping out.
Rotate the tool away from the Xbox prying open the bottom plate. Continue that step for all the remaining clips.
The top panel is very similar to the bottom panel removal. There will be thirteen clips you need to undo.
Make sure the front of the Xbox is facing towards the left. Then use the tool undo the clips just like you did on the bottom panel.
DO NOT BREAK ANY OF THE CLIPS.
Altre 4 persone hanno completato questa guida.
