Introduzione
This guide can be used for repair/refurbishing purposes
DO NOT work on the power supply while it is plugged in or while the white/orange indicator light is on. High voltage capacitors, while charged, can seriously injure or kill you. Exercise caution during this repair.
Cosa ti serve
Remove the top shell, flip it over, and place next to lower shell
Using a craft knife, carefully cut through the epoxy to get the cable free. Work slowly and carefully. The thick substance and awkward angles make this a slightly tedious process
Remove PH2 screws
Remove PH1 screws
Removal unnecessary
Disconnect cooling fan plug
Pull wire through
Remove tape in order to remove fan from its housing unit. This also uncovers a hidden screw.
Remove 4 PH0 screws
Remove fan upper housing plate
Gently lift the fan up and over the post
The fans +/- wires are covered by a thin protective sleeve.
Apply some electrical or kaptom tape to patch it if necessary.
Remove PCB from lower shell and place face down
To quickly and safely remove I suggest using ChipQuik on the 2 single sided through holes. Alternatively you can use solder wick
Altre 17 persone hanno completato questa guida.
