Salta al contenuto principale
Xbox 360 S Laser Lens Replacement
Cosa ti serve
  1. Xbox 360 S Laser Lens Replacement, How to get to your optical drive (follow link in the instructions): passo 1, immagine 1 di 1
    • Xbox 360 S Optical Drive Replacement
    • In order to get to the laser to replace it you first have to remove the disk drive.
    • The link at the top is an IFIXIT guide that helps you to remove and replace the optical disk drive.
    • For a new laser lens that comes with an anti-static solder joint consult the video guide to remove the solder joint.
    • https://youtu.be/iL8wVC9PLBk
    • When you purchase a new lens some come with the solder joint and some do not.
    • In the case that it does you'll need to desolder it. We provided a video to help you.
  2. Xbox 360 S Laser Lens Replacement, Start of the repair - how to get to the laser: passo 3, immagine 1 di 3 Xbox 360 S Laser Lens Replacement, Start of the repair - how to get to the laser: passo 3, immagine 2 di 3 Xbox 360 S Laser Lens Replacement, Start of the repair - how to get to the laser: passo 3, immagine 3 di 3
    • Now that you have completed steps 1 and 2
    • Remove the elastic band on the disk drive.
  3. Xbox 360 S Laser Lens Replacement: passo 4, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 4, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 4, immagine 3 di 3
    • With the underside exposed, identity the 4 main screws.
    • Remove these 4 screws.
    • Remove the cover to expose the assembly
  4. Xbox 360 S Laser Lens Replacement: passo 5, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 5, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 5, immagine 3 di 3
    • Locate the three ribbons connected to the board.
    • Use the plastic spudger to unclamp the ribbons from the board.
  5. Xbox 360 S Laser Lens Replacement: passo 6, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • The ribbons will now be able to slip out. With the tweezers, gently pull the ribbons to completely detach them.
  6. Xbox 360 S Laser Lens Replacement: passo 7, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 7, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 7, immagine 3 di 3
    • Locate the screw that holds the motherboard to the disk drive
    • Using your screwdriver, remove the motherboard screw.
  7. Xbox 360 S Laser Lens Replacement: passo 8, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 8, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 8, immagine 3 di 3
    • Use the spudger's flat side to get under the biggest plastic pin on edge of the board.
    • Push the pin backwards and off of the board.
    • Using your spudger again, push the second smaller pin backwards and off of the board.
    • Then, slide the board away from the pin slightly to be free of the last plastic element (the black corner thing).
  8. Xbox 360 S Laser Lens Replacement: passo 9, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 9, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 9, immagine 3 di 3
    • With the board freed from it's trappings, locate the pin securing the wires connected the board.
    • Be careful to not yank the motherboard or else the wires will rip from their sockets
    • Use your spudger to press this pin backwards.
    • Lift the entire board up to free the wires.
    • Lay the motherboard adjacent to the disk drive.
  9. Xbox 360 S Laser Lens Replacement: passo 10, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 10, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 10, immagine 3 di 3
    • Locate the 4 circular hex screws that secure the laser rail assembly.
    • Using your T6 hex screw driver remove these 4 screws.
  10. Xbox 360 S Laser Lens Replacement: passo 11, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 11, immagine 2 di 2
    • Lift the rail assembly out of the disk drive. Set the disk drive aside.
  11. Xbox 360 S Laser Lens Replacement: passo 12, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 12, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 12, immagine 3 di 3
    • Flip the laser rail assembly over to expose the screws.
    • Remove the screw connecting the laser lens to the plastic fastener.
  12. Xbox 360 S Laser Lens Replacement: passo 13, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 13, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 13, immagine 3 di 3
    • Remove the screw connecting the metal fastener to the rail.
    • Remove the metal fastener that holds the rod to the rail after removing the screw.
  13. Xbox 360 S Laser Lens Replacement: passo 14, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 14, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 14, immagine 3 di 3
    • Push the rail end to the side and out from under the metal latch.
    • Slide the lens off the rail. Set aside the rail assembly.
  14. Xbox 360 S Laser Lens Replacement: passo 15, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 15, immagine 2 di 2
    • Using the spudger, release the plastic clamp holding the ribbon to the laser lens.
    • Using your fingers gently pull the ribbon out of the plastic clamp.
  15. Xbox 360 S Laser Lens Replacement: passo 16, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 16, immagine 2 di 2
    • This is the lens
    • Remove the screw holding the metal fastener to the old lense.
    • Remove the now unsecured metal fastener.
  16. Xbox 360 S Laser Lens Replacement: passo 17, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 17, immagine 2 di 2
    • Connect the ribbon to the replacement lens by sliding it in place then closing the plastic fastener.
    • Place the removed metal fastener on the new laser lens and use the removed screw to secure the fastener to the replacement lens.
  17. Xbox 360 S Laser Lens Replacement: passo 18, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 18, immagine 2 di 2
    • Slide the replacement lens onto the right rail
    • Make sure to clip the other side of the lens onto the left rail
  18. Xbox 360 S Laser Lens Replacement: passo 19, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 19, immagine 2 di 2
    • Slide the unsecured right rail back under the metal latch. (metal latch is pointed to by the arrow)
    • Place the metal fastener removed from the rail previously back in position and secure it with the screw that was removed.
  19. Xbox 360 S Laser Lens Replacement: passo 20, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 20, immagine 2 di 2
    • Retrieve the plastic fastener and the accompanying screw.
    • Reattach the plastic fastener to the laser lens and use your philips head screw driver to re-secure the screw. The lens should now be attached to the rail.
  20. Xbox 360 S Laser Lens Replacement: passo 21, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 21, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 21, immagine 3 di 3
    • Position the rail assembly within the disk drive
    • Use the 4 previously removed screws to secure the position.
  21. Xbox 360 S Laser Lens Replacement: passo 22, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 22, immagine 2 di 2
    • Place the motherboard back in position.
    • Use the plastic pins to resecure the motherboard back to the disk drive.
    • Refer to steps 8 & 9 if more pictures for assistance are needed.
    • Just work backwards starting with only the first picture in 9, securing the wires into their enclosure using their pin.
    • Then work backwards through the pictures in step 8.
  22. Xbox 360 S Laser Lens Replacement: passo 23, immagine 1 di 3 Xbox 360 S Laser Lens Replacement: passo 23, immagine 2 di 3 Xbox 360 S Laser Lens Replacement: passo 23, immagine 3 di 3
    • Reattach the 3 ribbon wires to the motherboard.
    • These are the 3 wires that were detached in steps 5 & 6
    • If more assistance is needed work backwards completely through steps 6 and then 5.
    • Reattach the screw removed from the motherboard in step 7. This is the only screw that'll completely secure the motherboard to the disk drive.
  23. Xbox 360 S Laser Lens Replacement: passo 24, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 24, immagine 2 di 2
    • Replace the cover remove the cover
    • Flip the disk drive over and reattach the four screws removed from the cover in step 4.
  24. Xbox 360 S Laser Lens Replacement: passo 25, immagine 1 di 2 Xbox 360 S Laser Lens Replacement: passo 25, immagine 2 di 2
    • Flip the disk drive and reattach the elastic band.
    • You are done with replacing the laser lens.
    • Nice Job!
Conclusione
If you followed all the steps you should have a working XBOX 360 S.
Altre 7 persone hanno completato questa guida.
KEB
Membro da: 07/31/17
341 Reputazione
1 Guida realizzata
Un commento
Thanks, took me around 30 min to do this. Everything is written in detail. I like that.
GetToHellOut - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 122
Tutti i Tempi: 8,300
