Salta al contenuto principale
Xbox 360 S Hard Drive Replacement
Cosa ti serve
  1. Xbox 360 S Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 3 Xbox 360 S Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 3 Xbox 360 S Hard Drive Replacement, Hard Drive: passo 1, immagine 3 di 3
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  2. Xbox 360 S Hard Drive Replacement: passo 2, immagine 1 di 3 Xbox 360 S Hard Drive Replacement: passo 2, immagine 2 di 3 Xbox 360 S Hard Drive Replacement: passo 2, immagine 3 di 3
    • Firmly grasp the fabric tab labeled "250 GB" attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
    If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
    yamboboy - Replica
    You will still have your saves and account if you replace your hard drive in the new xbox
    Robert Miller -
    hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
    Cesar Tourreilles - Replica
    My fabric was accidentally ripped off years ago. What do I do?
    org 2026 - Replica
    Stick another bit on there
    Josh Cool -
Conclusione
Altre 96 persone hanno completato questa guida.
Brett Hartt
Membro da: 04/12/10
126.976 Reputazione
143 Guide realizzate
iFixit Membro di iFixit
Community
136 Membri
15.167 Guide realizzate
4 Commenti
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
David Johnson - Replica
no the os is on the internal drive all the hard drive is doing is adding more storge space
Nightwolf Gamer -
My hardrive says its unformated but its not and i dont want to loose content
Javier Eduardo Pacheco Hazim - Replica
Can I take the external out of the little black cover?
Lallie Cooney - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 17
Ultimi 7 Giorni: 131
Ultimi 30 Giorni: 597
Tutti i Tempi: 140,184
