Introduzione
Use this guide if the connections in the back of your Xbox 360 E aren't working. Replacing the motherboard requires a little more time than replacing other parts of your Xbox.
Cosa ti serve
Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
Looking at the body of the device, locate the green panel to the right of the CD drive.
Remove the two 6 mm screws located on the top left and middle right with a T8 Torx screwdriver.
Grip the middle of the green board and gently pull it out.
Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
Lift the bottom body slightly away from the core at a 45 degree angle.
Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
From the bottom of your Xbox, take your T9 torx screwdriver and take out all of the 11 mm screws labelled B1-7
Don't forget a screw on the side of the Xbox next to the power plug.
Altre 36 persone hanno completato questa guida.
4 Commenti
Where can I get the motherboard?
Need a motherboard.....
How did you go finding one ? , I gotta get one I think , any chance u could get hold of me by email or I'm on fb ? , just wanna ask you about something with xbox memory n error cap
Would have been nice to include the heatsink removal procedure even if it is similar to the original 360. Also I have never had extra screws left over, yet I have 2 phillips screws left over which are mentioned nowhere in this guide. From no point of the teardown process could I find where they came from.
