Introduzione
This guide is a prerequisite for replacing other parts of the Xbox 360 E.
Cosa ti serve
In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
Altre 6 persone hanno completato questa guida.
Un commento
Where can I find a new ribbon cable for Xbox 360 e? In addition, can very minuscule damage to cable cause the power button to turn red?
