Salta al contenuto principale
X-Treme Tablet Generation 2 Speaker Replacement
Cosa ti serve
  1. X-Treme Tablet Generation 2 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Using a spudger and pry tool, remove the back cover. Start at the top corner, and carefully pry the back cover off of the main body.
    • Continue around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Speaker Replacement: passo 2, immagine 1 di 2 X-Treme Tablet Generation 2 Speaker Replacement: passo 2, immagine 2 di 2
    • Using a solder vacuum and soldering iron, release the red wire from the motherboard first, then release the black wire.
    • The speaker is held on the back cover with adhesive tape. Using a pry tool, carefully pry the speaker from the back cover.
Conclusione
Altre 2 persone hanno completato questa guida.
Kristen John
Membro da: 01/26/15
125 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 327
