Salta al contenuto principale
Wyze WVCR200s Brush Roll Replacement
  1. Wyze WVCR200s Brush Roll Replacement, Brush Roll: passo 1, immagine 1 di 1
    • Flip the vacuum upside down so the bottom is facing up.
    • In the center of the device, you should see the rotating brush that stretches from one wheel to the other.
  2. Wyze WVCR200s Brush Roll Replacement: passo 2, immagine 1 di 2 Wyze WVCR200s Brush Roll Replacement: passo 2, immagine 2 di 2
    • Pinch the blue tabs below the rotating brush towards each other.
    • Lift the plastic housing surrounding the rotating brushing straight up, and the remove it from the vacuum.
  3. Wyze WVCR200s Brush Roll Replacement: passo 3, immagine 1 di 3 Wyze WVCR200s Brush Roll Replacement: passo 3, immagine 2 di 3 Wyze WVCR200s Brush Roll Replacement: passo 3, immagine 3 di 3
    • To remove the rotating brush, lift one end of the brush upwards, and remove.
Conclusione
Brendan
Membro da: 03/20/23
181 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 203
