Introduzione
If the battery of your Wyze WVCR200s robot vacuum isn't charging or won't hold a charge, you may need to replace the battery. This guide demonstrates how to replace the battery of your Wyze WVCR200s. Start off by checking the connection from the battery to the port. For your safety, make sure the device in fully powered down before attempting to remove the battery.
Cosa ti serve
Use a screwdriver to remove four screws along the edge, just above where the brush was removed.
