Salta al contenuto principale
Wyze Cam V2 Motherboard Replacement
Cosa ti serve
  1. Wyze Cam V2 Motherboard Replacement, Back Panel: passo 1, immagine 1 di 1
    • Open up the camera stand to expose the bottom plate of the camera.
    • Remove two 4 mm silver screws using the Phillips #0 screwdriver.
  2. Wyze Cam V2 Motherboard Replacement: passo 2, immagine 1 di 1
    • Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
  3. Wyze Cam V2 Motherboard Replacement: passo 3, immagine 1 di 2 Wyze Cam V2 Motherboard Replacement: passo 3, immagine 2 di 2
    • Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
    • Be careful of the charging port while taking it off.
  4. Wyze Cam V2 Motherboard Replacement: passo 4, immagine 1 di 2 Wyze Cam V2 Motherboard Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    $3.99
  5. Wyze Cam V2 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
    • Carefully remove the motherboard from the device.
  6. Wyze Cam V2 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the remaining two 6 mm screws from the motherboard with a Phillips #0 screwdriver.
  7. Wyze Cam V2 Motherboard Replacement: passo 7, immagine 1 di 1
    • Using the precision tweezers, detach the charging port’s motherboard from the camera’s motherboard.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 22
Tutti i Tempi: 410
