Salta al contenuto principale
WowWee Miposaur Wheel Replacement
Cosa ti serve
  1. WowWee Miposaur Wheel Replacement, Wheel: passo 1, immagine 1 di 1
    • Remove the 1.2 mm Phillips screws surrounding the wheel and take off the wheel cover.
  2. WowWee Miposaur Wheel Replacement: passo 2, immagine 1 di 1
    • Remove 1.2 mm Phillips screw from the white plastic piece in the center of the wheel and then remove the wheel entirely.
Conclusione
Samir Himes
Membro da: 10/22/18
126 Reputazione
1 Guida realizzata
UC Davis, Team S4-G3, Lore Fall 2018 Membro di UC Davis, Team S4-G3, Lore Fall 2018
UCD-LORE-F18S4G3
3 Membri
2 Guide realizzate
Un commento
This will require a TON of pressure on the screw. I tried it. The wheel is removable even without taking out the screw, since it does not require much force this way, either.
Michael Deitz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 510
