Salta al contenuto principale
WowWee MiP Robot Wheel Replacement
Cosa ti serve
  1. WowWee MiP Robot Wheel Replacement, Wheel: passo 1, immagine 1 di 2 WowWee MiP Robot Wheel Replacement, Wheel: passo 1, immagine 2 di 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  2. WowWee MiP Robot Wheel Replacement: passo 2, immagine 1 di 2 WowWee MiP Robot Wheel Replacement: passo 2, immagine 2 di 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  3. WowWee MiP Robot Wheel Replacement: passo 3, immagine 1 di 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
Conclusione
USF Tampa, Team 3-4, Wollert Spring 2016 Membro di USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 898
