Salta al contenuto principale
WowWee MiP Robot Body Disassembly
Cosa ti serve
  1. WowWee MiP Robot Body Disassembly, Battery: passo 1, immagine 1 di 2 WowWee MiP Robot Body Disassembly, Battery: passo 1, immagine 2 di 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Body Disassembly: passo 2, immagine 1 di 2 WowWee MiP Robot Body Disassembly: passo 2, immagine 2 di 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot Body Disassembly, Wheel: passo 3, immagine 1 di 2 WowWee MiP Robot Body Disassembly, Wheel: passo 3, immagine 2 di 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot Body Disassembly: passo 4, immagine 1 di 2 WowWee MiP Robot Body Disassembly: passo 4, immagine 2 di 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot Body Disassembly: passo 5, immagine 1 di 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot Body Disassembly, WowWee MiP Robot Body Disassembly: passo 6, immagine 1 di 2 WowWee MiP Robot Body Disassembly, WowWee MiP Robot Body Disassembly: passo 6, immagine 2 di 2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot Body Disassembly: passo 7, immagine 1 di 3 WowWee MiP Robot Body Disassembly: passo 7, immagine 2 di 3 WowWee MiP Robot Body Disassembly: passo 7, immagine 3 di 3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot Body Disassembly: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 3-4, Wollert Spring 2016 Membro di USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,748
