Salta al contenuto principale
WowWee CHiP Robot Dog Wheel Replacement
Cosa ti serve
  1. WowWee CHiP Robot Dog Wheel Replacement, Battery: passo 1, immagine 1 di 1
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Wheel Replacement: passo 2, immagine 1 di 2 WowWee CHiP Robot Dog Wheel Replacement: passo 2, immagine 2 di 2
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Wheel Replacement: passo 3, immagine 1 di 2 WowWee CHiP Robot Dog Wheel Replacement: passo 3, immagine 2 di 2
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Wheel Replacement: passo 4, immagine 1 di 3 WowWee CHiP Robot Dog Wheel Replacement: passo 4, immagine 2 di 3 WowWee CHiP Robot Dog Wheel Replacement: passo 4, immagine 3 di 3
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Wheel Replacement, Wheel: passo 5, immagine 1 di 1
    • Locate wheel to replace.
  6. WowWee CHiP Robot Dog Wheel Replacement: passo 6, immagine 1 di 1
    • Twist grey wheel cap in counter-clockwise rotation.
  7. WowWee CHiP Robot Dog Wheel Replacement: passo 7, immagine 1 di 1
    • Pull and remove wheel.
Conclusione
Altre 3 persone hanno completato questa guida.
3 Commenti
Why do you have to disconnect the battery before changing the wheel? Can you not just turn off the power and change it?
shawna_beji - Replica
зачем снимать акб?
замена или снятие колес происходит при простом отключении устройства обычным выключателем.
Руслан Смоленск - Replica
Heads up it is really hard to turn
Mary Pownsu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 38
Tutti i Tempi: 4,269
