Salta al contenuto principale
World Dryer Airforce J4-973A3 Server Board Replacement
Cosa ti serve
  1. World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: passo 1, immagine 1 di 3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: passo 1, immagine 2 di 3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: passo 1, immagine 3 di 3
    • Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
    • The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. World Dryer Airforce J4-973A3 Server Board Replacement: passo 2, immagine 1 di 2 World Dryer Airforce J4-973A3 Server Board Replacement: passo 2, immagine 2 di 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
    Chiedi a FixBot
    Aggiungi Commento
  3. World Dryer Airforce J4-973A3 Server Board Replacement: passo 3, immagine 1 di 3 World Dryer Airforce J4-973A3 Server Board Replacement: passo 3, immagine 2 di 3 World Dryer Airforce J4-973A3 Server Board Replacement: passo 3, immagine 3 di 3
    • Remove all three 1/2" Ph1 screws connecting the server board to the device.
    • During reassembly, install the screws before reattaching the wires.
    Chiedi a FixBot
    Aggiungi Commento
  4. World Dryer Airforce J4-973A3 Server Board Replacement: passo 4, immagine 1 di 3 World Dryer Airforce J4-973A3 Server Board Replacement: passo 4, immagine 2 di 3 World Dryer Airforce J4-973A3 Server Board Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    • Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
    • After these steps, the server board should easily come off the side of the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 41
Tutti i Tempi: 553
