Salta al contenuto principale
World Dryer Airforce J4-973A3 Motor Replacement
Cosa ti serve
  1. World Dryer Airforce J4-973A3 Motor Replacement, Motor: passo 1, immagine 1 di 3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: passo 1, immagine 2 di 3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: passo 1, immagine 3 di 3
    • To change the motor, start by removing the metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
    Chiedi a FixBot
    Aggiungi Commento
  2. World Dryer Airforce J4-973A3 Motor Replacement: passo 2, immagine 1 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 2, immagine 2 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 2, immagine 3 di 3
    • Remove the three 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the device.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a small prier.
    • Carefully remove the cap, to prevent damage to the sensor.
    Chiedi a FixBot
    Aggiungi Commento
  3. World Dryer Airforce J4-973A3 Motor Replacement: passo 3, immagine 1 di 2 World Dryer Airforce J4-973A3 Motor Replacement: passo 3, immagine 2 di 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
    Chiedi a FixBot
    Aggiungi Commento
  4. World Dryer Airforce J4-973A3 Motor Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    Chiedi a FixBot
    Aggiungi Commento
  5. World Dryer Airforce J4-973A3 Motor Replacement: passo 5, immagine 1 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 5, immagine 2 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 5, immagine 3 di 3
    • Remove the brass nut from its bolt using a 10mm wrench.
    • Once the nut is free, disconnect the green wire.
    Chiedi a FixBot
    Aggiungi Commento
  6. World Dryer Airforce J4-973A3 Motor Replacement: passo 6, immagine 1 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 6, immagine 2 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 6, immagine 3 di 3
    • Remove the rainbow ribbon cable using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  7. World Dryer Airforce J4-973A3 Motor Replacement: passo 7, immagine 1 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 7, immagine 2 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 7, immagine 3 di 3
    • Remove the four 3/4" Ph2 screws from the back of the device body.
    • Separate the motor housing from the device body.
    • Ensure that all wires connecting the motor housing and motherboard are disconnected before removing the component.
    Chiedi a FixBot
    Aggiungi Commento
  8. World Dryer Airforce J4-973A3 Motor Replacement: passo 8, immagine 1 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 8, immagine 2 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 8, immagine 3 di 3
    • Remove the four 1/2" Ph2 screws from the filter.
    • Pull the filter plate away to reveal the motor.
    Chiedi a FixBot
    Aggiungi Commento
  9. World Dryer Airforce J4-973A3 Motor Replacement: passo 9, immagine 1 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 9, immagine 2 di 3 World Dryer Airforce J4-973A3 Motor Replacement: passo 9, immagine 3 di 3
    • Pull the motor out of the housing.
    • Be sure to feed the wires through the slot as you pull the motor out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Eli Forbes
Membro da: 09/17/18
172 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 12
Ultimi 30 giorni: 66
Tutti i Tempi: 685
