Salta al contenuto principale
World Dryer Airforce J4-973A3 Air Filter Replacement
Cosa ti serve
  1. World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: passo 1, immagine 1 di 3 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: passo 1, immagine 2 di 3 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: passo 1, immagine 3 di 3
    • In order to change the air filter, start with the removal of the outer metal casing. Use the appropriate security bit.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Air Filter Replacement: passo 2, immagine 1 di 3 World Dryer Airforce J4-973A3 Air Filter Replacement: passo 2, immagine 2 di 3 World Dryer Airforce J4-973A3 Air Filter Replacement: passo 2, immagine 3 di 3
    • To access both filters, unscrew all three 1/2" Ph2 screws.
    • Gently pull the plate away from the black, coarse filter.
  3. World Dryer Airforce J4-973A3 Air Filter Replacement: passo 3, immagine 1 di 2 World Dryer Airforce J4-973A3 Air Filter Replacement: passo 3, immagine 2 di 2
    • After removing the small grey filter, pull on the black, ring-shaped filter to remove it.
    • We recommend either vacuuming the filters or washing them to remove the dust that has accumulated on the filter.
    • Leave the filters out to dry for 24 hours before putting it back into use, in order to avoid water damage or electric shock!
Conclusione
Blane Hirsh
Membro da: 09/17/18
260 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 220
