Salta al contenuto principale
Wooting 60HE Keycap Replacement
Cosa ti serve
  1. Wooting 60HE Keycap Replacement, Keycap: passo 1, immagine 1 di 1
    • Use a small, soft bristle brush to remove small hairs or dust from the keyboard.
    • For this replacement, we will be replacing the "A" keycap.
  2. Wooting 60HE Keycap Replacement: passo 2, immagine 1 di 2 Wooting 60HE Keycap Replacement: passo 2, immagine 2 di 2
    • Hook the two metal brackets of the keycap puller at a slight angle on the corners of the key.
    • Slightly tug upwards, and the key should come out smoothly. Place the key to the side.
    • It is essential to be gentle; excessive force can cause cracks or scratches on the key.
  3. Wooting 60HE Keycap Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, carefully extract debris from the exposed backboard of the keyboard.
    • Try to avoid the key nub, as it is lubricated, and outside contact can ruin it.
  4. Wooting 60HE Keycap Replacement: passo 4, immagine 1 di 1
    • Hold a multi-purpose electronics duster three inches away and at an angle from the exposed key.
    • Press the trigger in short bursts.
    • This will help get rid of any debris that you could not get from using your tweezers.
  5. Wooting 60HE Keycap Replacement: passo 5, immagine 1 di 2 Wooting 60HE Keycap Replacement: passo 5, immagine 2 di 2
    • Place a cotton swab on a napkin and lightly coat the head of the swab with 70% isopropyl alcohol.
  6. Wooting 60HE Keycap Replacement: passo 6, immagine 1 di 1
    • Gently pat around the white backboard of the keyboard with the cotton swab.
    • This will help get rid of any built up residue, oils, or any possible spills that could have occurred in the past.
    • Isopropyl alcohol can strip the lubricant on the key, so put emphasis on dabbing the white backboard and not the key itself.
  7. Wooting 60HE Keycap Replacement: passo 7, immagine 1 di 3 Wooting 60HE Keycap Replacement: passo 7, immagine 2 di 3 Wooting 60HE Keycap Replacement: passo 7, immagine 3 di 3
    • Line the keycap in the upright position above the nub and press down lightly.
    • The key should slide back in place.
Linea Traguardo
Aryav Balia
Membro da: 10/25/23
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 39
Tutti i Tempi: 379
