Salta al contenuto principale
Wood Stool Leg Glide Replacement
Cosa ti serve
  1. Wood Stool Leg Glide Replacement, Wood Stool Leg Glides: passo 1, immagine 1 di 1
    • Turn the stool upside down so it is stable on the ground and the legs are faced up in the air.
  2. Wood Stool Leg Glide Replacement: passo 2, immagine 1 di 1
    • Clean the end of the sled gliders and the legs to remove dust and debris.
  3. Wood Stool Leg Glide Replacement: passo 3, immagine 1 di 1
    • Peel the sled glides off of the top of the screw on glides on all four of the legs.
  4. Wood Stool Leg Glide Replacement: passo 4, immagine 1 di 1
    • Use a 1.59mm drill bit and unscrew the screw from all four legs. Then remove the screw on glides.
    • Make sure the drill is faced straight up and down or the screw will become stripped.
  5. Wood Stool Leg Glide Replacement: passo 5, immagine 1 di 1
    • Pry the remaining part of the screw with a hammer if the screw is not drilled out all of the way.
  6. Wood Stool Leg Glide Replacement: passo 6, immagine 1 di 1
    • Use a 1.59mm drill bit to drill on the new screw on glides in the center of all four stool legs.
  7. Wood Stool Leg Glide Replacement: passo 7, immagine 1 di 2 Wood Stool Leg Glide Replacement: passo 7, immagine 2 di 2
    • Stick the new sled glider at the center of the screw on glides for all four legs.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 378
