Salta al contenuto principale
Wolf Gourmet WGTR102S Slide Assist Plunger Replacement
Cosa ti serve
  1. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Outer Shell: passo 1, immagine 1 di 1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 2, immagine 1 di 1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 3, immagine 1 di 1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 4, immagine 1 di 1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 5, immagine 1 di 1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 6, immagine 1 di 1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 7, immagine 1 di 1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 8, immagine 1 di 2 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 8, immagine 2 di 2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Slide Assist Plunger: passo 9, immagine 1 di 1
    • Remove the top panel by bending the tabs on each side straight up.
  10. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 10, immagine 1 di 1
    • Remove the two 8mm screws on the bottom of the plunger using a Tri-point Y1 screwdriver.
  11. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 11, immagine 1 di 2 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 11, immagine 2 di 2
    • Remove the plunger from the device.
Conclusione
Ryan Funchess
Membro da: 04/19/18
697 Reputazione
5 Guide realizzate
Cal Poly, Team S22-G5, Maness Spring 2018 Membro di Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Membri
5 Guide realizzate
4 Commenti
Where does one get a new plunger for the replacement?
hsernaker - Replica
yes, where does one get a new pludger?
hiyar124 - Replica
Has anyone found a source for the WOLF toaster plunger?
Rick Guest - Replica
Any pointers on where to find Wolf replacement parts ?
Stefano Concina - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,074
