Salta al contenuto principale
Wolf Gourmet WGTR102S Lighting Component Replacement
Cosa ti serve
  1. Wolf Gourmet WGTR102S Lighting Component Replacement, Outer Shell: passo 1, immagine 1 di 1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Lighting Component Replacement: passo 2, immagine 1 di 1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Lighting Component Replacement: passo 3, immagine 1 di 1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Lighting Component Replacement: passo 4, immagine 1 di 1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Lighting Component Replacement: passo 5, immagine 1 di 1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Lighting Component Replacement: passo 6, immagine 1 di 1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Lighting Component Replacement: passo 7, immagine 1 di 1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Lighting Component Replacement: passo 8, immagine 1 di 2 Wolf Gourmet WGTR102S Lighting Component Replacement: passo 8, immagine 2 di 2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Lighting Component Replacement, Lighting Component: passo 9, immagine 1 di 1
    • Remove two 8mm screws securing the lighting component using a Tri-point Y1 screwdriver.
  10. Wolf Gourmet WGTR102S Lighting Component Replacement: passo 10, immagine 1 di 1
    • Remove the lighting component from the device.
Conclusione
Ryan Funchess
Membro da: 04/19/18
697 Reputazione
5 Guide realizzate
Cal Poly, Team S22-G5, Maness Spring 2018 Membro di Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Membri
5 Guide realizzate
Un commento
Hi, do you have an idea how to remove the beeping sound? It's annoying, I want to remove it
Thank you
francis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 238
