Salta al contenuto principale
Wolf Gourmet WGBL100S Power Cord Replacement
Cosa ti serve
  1. Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: passo 1, immagine 1 di 2 Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: passo 1, immagine 2 di 2
    • With the bottom of the blender facing up, use a Phillips #2 screwdriver to remove the 4, 1/2 inch long screws in the corners of the device.
    • Ensure the blender is off and unplugged before starting.
  2. Wolf Gourmet WGBL100S Power Cord Replacement: passo 2, immagine 1 di 2 Wolf Gourmet WGBL100S Power Cord Replacement: passo 2, immagine 2 di 2
    • Using a metal spudger, pry up one side of each of the rubber feet.
    • Note that one side of each foot is glued down; pry up the non-glued side.
  3. Wolf Gourmet WGBL100S Power Cord Replacement: passo 3, immagine 1 di 1
    • Using the same Phillips #2 screwdriver, unscrew the 1/2 inch long screw under each of the feet.
  4. Wolf Gourmet WGBL100S Power Cord Replacement: passo 4, immagine 1 di 2 Wolf Gourmet WGBL100S Power Cord Replacement: passo 4, immagine 2 di 2
    • Pull off the base and remove the plastic housing underneath.
  5. Wolf Gourmet WGBL100S Power Cord Replacement: passo 5, immagine 1 di 2 Wolf Gourmet WGBL100S Power Cord Replacement: passo 5, immagine 2 di 2
    • On the underside of the base, unscrew the three 3/8" long screws on the plastic piece holding the power cord in place using a Phillips #1 screwdriver.
    • Pull the plastic cover off.
  6. Wolf Gourmet WGBL100S Power Cord Replacement: passo 6, immagine 1 di 1
    • Using a wire cutter, cut the three wires of the power cord.
  7. Wolf Gourmet WGBL100S Power Cord Replacement: passo 7, immagine 1 di 2 Wolf Gourmet WGBL100S Power Cord Replacement: passo 7, immagine 2 di 2
    • Pull the cut power cord through the base.
    • Then thread the replacement cord back through and re-attach the plastic cover.
  8. Wolf Gourmet WGBL100S Power Cord Replacement: passo 8, immagine 1 di 3 Wolf Gourmet WGBL100S Power Cord Replacement: passo 8, immagine 2 di 3 Wolf Gourmet WGBL100S Power Cord Replacement: passo 8, immagine 3 di 3
    • Strip about an inch of insulation off of the snipped power cord and your replacement cord.
    • Twist each strand of wires together to keep them neat.
  9. Wolf Gourmet WGBL100S Power Cord Replacement: passo 9, immagine 1 di 2 Wolf Gourmet WGBL100S Power Cord Replacement: passo 9, immagine 2 di 2
    • Twist together the wires from the replacement cord to the wires still attached to the blender.
    • Solder the connection if possible.
  10. Wolf Gourmet WGBL100S Power Cord Replacement: passo 10, immagine 1 di 2 Wolf Gourmet WGBL100S Power Cord Replacement: passo 10, immagine 2 di 2
    • Wrap all the connections in electrical tape or heat shrink tubing.
Conclusione
To reassemble your device, follow steps 1-5 in reverse order.
Cal Poly, Team S25-G16, Maness Spring 2018 Membro di Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 267
