Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
If your blender does not operate, try opening it as per this guide and checking the wires on the control board. If that yields no results, consider replacing the board if possible.
  1. Flip the base of the blender upside-down. Remove the four 1/2" long screws in the corners of the base using a Phillips #2 screwdriver.
    • Flip the base of the blender upside-down.
    • Remove the four 1/2" long screws in the corners of the base using a Phillips #2 screwdriver.
  2. Using the metal spudger,  pry off one half of each rubber foot. Note that one side of the foot is glued down; pry off the other side.
    • Using the metal spudger, pry off one half of each rubber foot.
    • Note that one side of the foot is glued down; pry off the other side.
  3. Using the same screwdriver, remove the next four 1/2" long screws in the holes under the feet.
    • Using the same screwdriver, remove the next four 1/2" long screws in the holes under the feet.
    • Pull the base off of the blender.
  4. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Pull off the plastic housing. Pull off the plastic housing.
    • Pull off the plastic housing.
  6. Using the same Phillips #2 screwdriver, remove the two 3/4" long screws holding the control board in place. Using the same Phillips #2 screwdriver, remove the two 3/4" long screws holding the control board in place.
    • Using the same Phillips #2 screwdriver, remove the two 3/4" long screws holding the control board in place.
  7. Using pliers, pull off all the connectors on the top. Using pliers, pull off all the connectors on the top.
    • Using pliers, pull off all the connectors on the top.
  8. Pull or pry off the last connector block, then remove the control board.
    • Pull or pry off the last connector block, then remove the control board.
Conclusione
Cole Gillespie
Membro da: 19/04/2018
464 Reputazione
2 Guide realizzate
Cal Poly, Team S25-G16, Maness Spring 2018 Membro di Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 92
