Salta al contenuto principale
Wolf Gourmet WGBL100S Blades Replacement
Cosa ti serve
  1. Wolf Gourmet WGBL100S Blades Replacement, Blender Blades: passo 1, immagine 1 di 1
    • Flip over the pitcher to expose the base of the blade assembly.
    • Using the H4.0 Allen key from the 54 bit driver kit, attached to an impact driver, remove the socket head cap screw from the drive coupling.
    • Apply a solvent to remove adhesive if necessary.
  2. Wolf Gourmet WGBL100S Blades Replacement: passo 2, immagine 1 di 1
    • Using a pair of pliers, pull of the drive shaft coupling.
  3. Wolf Gourmet WGBL100S Blades Replacement: passo 3, immagine 1 di 2 Wolf Gourmet WGBL100S Blades Replacement: passo 3, immagine 2 di 2
    • Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
  4. Wolf Gourmet WGBL100S Blades Replacement: passo 4, immagine 1 di 1
    • Remove the nut using a crescent wrench.
  5. Wolf Gourmet WGBL100S Blades Replacement: passo 5, immagine 1 di 1
    • Push the blade assembly into the jar.
    • Remove the blades from the device.
    • Be careful not to cut yourself when handling the blades.
Conclusione
Luke Kutz
Membro da: 04/19/18
354 Reputazione
3 Guide realizzate
Cal Poly, Team S25-G16, Maness Spring 2018 Membro di Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
4 Membri
5 Guide realizzate
Un commento
Can anyone advise where to buy replacement blade
Nikki Turturro - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 770
