Salta al contenuto principale
Wireless Xbox One Controller Bumper Assembly Replacement
Cosa ti serve
  1. Wireless Xbox One Controller Bumper Assembly Replacement, Bumper Assembly: passo 1, immagine 1 di 1
    • Remove the battery cover from the back of the controller by sliding it upwards.
  2. Wireless Xbox One Controller Bumper Assembly Replacement: passo 2, immagine 1 di 3 Wireless Xbox One Controller Bumper Assembly Replacement: passo 2, immagine 2 di 3 Wireless Xbox One Controller Bumper Assembly Replacement: passo 2, immagine 3 di 3
    • Using the halberd spudger, pry the grip casing upwards from the handle.
    • Remove the grip casing from both the left and right handles of the controller.
    • It helps to begin near the top of the grip casing near the trigger.
  3. Wireless Xbox One Controller Bumper Assembly Replacement: passo 3, immagine 1 di 2 Wireless Xbox One Controller Bumper Assembly Replacement: passo 3, immagine 2 di 2
    • Remove the five 9 mm Torx TR9 security screws from the top and bottom of the controller grip regions as well as from the center of the battery region.
    • The pins on the security screws can be broken off easily with a small flathead screwdriver for use of an ordinary Torx screwdriver if the security version is unavailable.
  4. Wireless Xbox One Controller Bumper Assembly Replacement: passo 4, immagine 1 di 1
    • Remove the back of the controller casing by lifting it up and off.
  5. Wireless Xbox One Controller Bumper Assembly Replacement: passo 5, immagine 1 di 1
    • Lift the internal assembly from the plastic controller case.
    • Handle gently; the motors on the bottom left and right are not firmly attached.
  6. Wireless Xbox One Controller Bumper Assembly Replacement: passo 6, immagine 1 di 2 Wireless Xbox One Controller Bumper Assembly Replacement: passo 6, immagine 2 di 2
    • Remove the top button panel from the controller by gently lifting up the hooks attached to the internals.
  7. Wireless Xbox One Controller Bumper Assembly Replacement: passo 7, immagine 1 di 1
    • Detach the bumper assembly by sliding one bumper to the side away from the controller and then lifting upwards.
    • Gently follow the motion indicated by the arrows.
  8. Wireless Xbox One Controller Bumper Assembly Replacement: passo 8, immagine 1 di 1
    • Remove bumpers and replace by inserting a new bumper assembly.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 2-2, Johann Winter 2023 Membro di Cal Poly, Team 2-2, Johann Winter 2023
CPSU-JOHANN-W23S2G2
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 64
Ultimi 30 Giorni: 302
Tutti i Tempi: 4,926
