Salta al contenuto principale
Wire Sunglasses Frame Lens Replacement
Cosa ti serve
  1. Wire Sunglasses Frame Lens Replacement, Sunglasses Lens: passo 1, immagine 1 di 2 Wire Sunglasses Frame Lens Replacement, Sunglasses Lens: passo 1, immagine 2 di 2
    • Place the missing lens against the upper rim of the glasses, feel free to fit the bottom wire underneath.
    Chiedi a FixBot
  2. Wire Sunglasses Frame Lens Replacement: passo 2, immagine 1 di 2 Wire Sunglasses Frame Lens Replacement: passo 2, immagine 2 di 2
    • While holding the frame in position, thread the plastic strip around the metal wire. The strip should sit around halfway through it.
    Chiedi a FixBot
  3. Wire Sunglasses Frame Lens Replacement: passo 3, immagine 1 di 2 Wire Sunglasses Frame Lens Replacement: passo 3, immagine 2 di 2
    • Using the plastic strip as an anchor, slowly re-fasten the wire underneath the bottom of the frame. Slide the strip from one end of the frame to the other.
    • The lens must remain firmly around the upper rim for the wire to slide underneath.
    Chiedi a FixBot
  4. Wire Sunglasses Frame Lens Replacement: passo 4, immagine 1 di 2 Wire Sunglasses Frame Lens Replacement: passo 4, immagine 2 di 2
    • Once the wire is under the frame, use the plastic strip to gently adjust the wire as needed.
    Chiedi a FixBot
  5. Wire Sunglasses Frame Lens Replacement: passo 5, immagine 1 di 2 Wire Sunglasses Frame Lens Replacement: passo 5, immagine 2 di 2
    • Once you are done, begin to remove the plastic strip from the frame.
    • Gently tug at one end of the strip to remove it from between the lens and the wire.
    Chiedi a FixBot
  6. Wire Sunglasses Frame Lens Replacement: passo 6, immagine 1 di 2 Wire Sunglasses Frame Lens Replacement: passo 6, immagine 2 di 2
    • Ensure the lens is secured by gently pushing it.
    • If the lens is still loose or needs to be re-adjusted, take the lens out and start again from Step 1.
    Chiedi a FixBot
Conclusione
Following these steps will help save time and money so you can continue enjoying your shades.
Violet Lampman
Membro da: 02/08/24
133 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 53
Tutti i Tempi: 455
