Salta al contenuto principale
Wire Bonder Thread Spool Replacement
Panoramica Video
  1. Wire Bonder Thread Spool Replacement, Wire Bonder Thread Spool Replacement: passo 1, immagine 1 di 1
    • Remove the seal from the wire spool. Take care not to cut the thread at the red marking!
  2. Wire Bonder Thread Spool Replacement: passo 2, immagine 1 di 1
    • Insert the spool in the assembly.
    • Make sure that the spool runs clockwise.
    • Pull the thread downward.
  3. Wire Bonder Thread Spool Replacement, Placing the thread into the infeeder: passo 4, immagine 1 di 1
    • Place the thread between the guides of the infeeder.
    • Pull the engaging knob which is situated to the left of the infeeder rolls, to the left.
    • Now there is a gap between the infeeder rolls into which the wire can be inserted safely.
  4. Wire Bonder Thread Spool Replacement, Placing the thread behind the sensors: passo 5, immagine 1 di 1
    • Cut the wire.
    • Place the wire behind the sensors (the black box in the foreground).
  5. Wire Bonder Thread Spool Replacement, Placing the thrad in the outfeeder: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use the tweezers to place the wire between the two metal guides of the outfeeder.
  6. Wire Bonder Thread Spool Replacement, Put the wire into the tube: passo 7, immagine 1 di 1
    • Use the tweezers to lead the wire into the tube from below.
  7. Wire Bonder Thread Spool Replacement, Automatic feeding: passo 8, immagine 1 di 1
    • Push the spring of the outfeeder and the "Feed and Capture" button simultaneously for automatic feeding.
    • Make sure that the rolls of the outfeeder are close together so that the wire is gripped firmly.
    • Before starting automatic feeding, turn off "Run or Service" and activate "Feed or Capture".
  8. Wire Bonder Thread Spool Replacement, Manual Feeding: passo 9, immagine 1 di 2 Wire Bonder Thread Spool Replacement, Manual Feeding: passo 9, immagine 2 di 2
    • It is also possible to feed the wire manually into the outfeeder tube.
    • In order to do so, press the "Run and Service" button and turn the left-hand wheel clockwise. The wire is now fed ino the tube.
  9. Wire Bonder Thread Spool Replacement: passo 10, immagine 1 di 1
    • Check visually if the wire is fed into the bonding head.
Conclusione
Beate Richter
Membro da: 03/20/19
181 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 194
