Salta al contenuto principale
Wintec Filemate Clear 7" Front Screen Replacement
Cosa ti serve
  1. Wintec Filemate Clear 7" Front Screen Replacement, Remove the Backplate: passo 1, immagine 1 di 1
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Front Screen Replacement: passo 2, immagine 1 di 2 Wintec Filemate Clear 7" Front Screen Replacement: passo 2, immagine 2 di 2
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Front Screen Replacement, Remove the Battery: passo 3, immagine 1 di 1
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Front Screen Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Front Screen Replacement: passo 5, immagine 1 di 1
    • Fully remove the battery from the device.
  6. Wintec Filemate Clear 7" Front Screen Replacement, Motherboard: passo 6, immagine 1 di 1
    • Locate each of the motherboard's 4 mm screws.
  7. Wintec Filemate Clear 7" Front Screen Replacement, Unscrewing Everything: passo 7, immagine 1 di 3 Wintec Filemate Clear 7" Front Screen Replacement, Unscrewing Everything: passo 7, immagine 2 di 3 Wintec Filemate Clear 7" Front Screen Replacement, Unscrewing Everything: passo 7, immagine 3 di 3
    • Remove each of the four 4 mm screws from the motherboard pictured to the left.
    • Use a Phillips #00 precision screwdriver.
  8. Wintec Filemate Clear 7" Front Screen Replacement, Detach the Motherboard: passo 8, immagine 1 di 2 Wintec Filemate Clear 7" Front Screen Replacement, Detach the Motherboard: passo 8, immagine 2 di 2
    • Use the spudger to pry the instrument array from its plastic housing.
  9. Wintec Filemate Clear 7" Front Screen Replacement: passo 9, immagine 1 di 1
    • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
    • Be careful not to harm the array of wires leading to this tape.
  10. Wintec Filemate Clear 7" Front Screen Replacement: passo 10, immagine 1 di 1
    • De-tatch the motherboard output wires from the screen using the tweezers.
  11. Wintec Filemate Clear 7" Front Screen Replacement, Front Screen: passo 11, immagine 1 di 1
    • Locate the front screen's screws.
  12. Wintec Filemate Clear 7" Front Screen Replacement, Remove the Extra Screws: passo 12, immagine 1 di 2 Wintec Filemate Clear 7" Front Screen Replacement, Remove the Extra Screws: passo 12, immagine 2 di 2
    • There are two additional 4 mm screws holding the front screen.
    • Use the Phillips #00 screwdriver to remove the screws (pictured to the left).
  13. Wintec Filemate Clear 7" Front Screen Replacement: passo 13, immagine 1 di 1
    • Fully remove the front screen from its plastic cover.
Conclusione
USF Tampa, Team 19-6, Blackwell Spring 2014 Membro di USF Tampa, Team 19-6, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G6
3 Membri
11 Guide realizzate
1Commento della guida
Hi, have a Filemate tablet and the front is broke . So is the Front and Digitizer the same thing? Thank you Brenda L Glidewell
Brenda L Glidewell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 229
