Salta al contenuto principale
Wintec Filemate Clear 7" Battery Replacement
Cosa ti serve
  1. Wintec Filemate Clear 7" Battery Replacement, Remove the Backplate: passo 1, immagine 1 di 1
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Battery Replacement: passo 2, immagine 1 di 2 Wintec Filemate Clear 7" Battery Replacement: passo 2, immagine 2 di 2
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Battery Replacement, Remove the Battery: passo 3, immagine 1 di 1
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Battery Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Battery Replacement: passo 5, immagine 1 di 1
    • Fully remove the battery from the device.
Conclusione
To reassemble your device, glue the new battery to where the old one was and solder the new power connectors where the old ones were. Then follow the instructions in reverse order.
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 19-6, Blackwell Spring 2014 Membro di USF Tampa, Team 19-6, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G6
3 Membri
11 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,131
