Windsor Willow Brake Pad Replacement
Introduzione
Vai al passo 1This process requires just one tool and the removal of the tire.
Cosa ti serve
To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
Hold the bicycle so that the bicycle wheels rests in the air and able to stand on its own.
The hex bolt is what fastens each brake pad to the caliper. We will need to remove these to replace each pad.
Using an open end 10mm wrench, unscrew the hex nut from the caliper. After the nut is loosened you can use your fingers to finish the job. Repeat the same process on the other side for removal of the second brake pad.
